Results 1 to 8 of 8
Thread: V6 Auto - wont go into drive for 10secs
    VY Exe
    Apr 2005
    Melb SE Suburbs
    Default V6 Auto - wont go into drive for 10secs
    Hi,
    When first start the car, it just wont go into gear, sometimes have to wait over 10secs. goes into reverse fine, i end up manually putting into first, then into drive.
    Spoke to a mechanic, he said the auto must come out to fix it, Lookin around 880 - 1200. Said I can keep driving it but it is possible that I may loose drive all together.
    Just wondering if anyone has had similar issues and got it fixed?
    Cheers.
    =WzA=
    2003 CV8R Monaro
    Mar 2008
    Liverpool
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Sounds like your forward Clutches are worn or maybe some sort of Electrical Fault ie Solenoid etc.
    How does it drive once its in Gear. Does it change gears smoothly or does it feel hesitant to change between gears.
    Definatly check your Fluid Level as well. Get Engine Warm, leave ideling and Remove the Trans Dipstick, Clean it, stick it back in and pull out again - The Fluid should be in the Hot Crossed section. If its not, you may need to top it up. (Usually with Dexron III)
    VY Exe
    Apr 2005
    Melb SE Suburbs
    Thanks,
    Once in gear there are no problems changing gears, yes unfortunately i never checked gearbox oil, but have since topped it up, it was near empty.
    =WzA=
    VY II V6
    Dec 2006
    I had a similar problem with my VY.. It just needed some more fluid.. IMO, time for a proper gearbox flush/service.. Only costs about $110-130 from any reputable workshop..
    -Nick.
    VT COMMODORE
    Dec 2008
    I've got the same problem - lost 2nd gear and reverse. Aparently Holden make cheap ****ty gear boxes and haven't changed them since the days of the VN, just added a few gizmos.
    There is a drive shaft (or something) that snaps off. It can happen to new or old Holdens. You will have to search long and hard to find a mechanic to replace the part, rather than replace the entire transmission. I am taking mine to Pier St Auto on Pier St. He was the only one who said he would replace the part - about $600-700.
    VY Exe
    Apr 2005
    Melb SE Suburbs
    Got the car serviced, found two leaks, cost $400 to fix and i am not having the problem anymore!
    Thanks for the replies.
    =WzA=
    VZ SV6
    Oct 2008
    Newcastle NSW
    Quote Originally Posted by VTCommoDude View Post
    its the sun gear/shell failing, its quite common in GM trannys and makes you only have 1st and 3rd - no reverse, 2nd and overdrive. there's a site around that has heaps of info on it and methods (when rebuidling) to make it stronger but i can't find it anymore.
  1. VN auto has no drive
    By newtownbob in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-07-2008, 03:25 PM
  2. H E L P me!! my vpss v8 auto stalls in drive!!
    By Dasampsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2006, 07:26 PM
  3. Auto hard changing second time in drive
    By Spaced in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2006, 12:32 PM
  4. vibration in Drive in vp auto
    By stewie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2005, 07:19 AM
  5. Auto Transmission - Drive or Overdrive
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2004, 05:05 PM
