Results 1 to 6 of 6
Thread: Boost Gauge
    Supercharged vy calais
    Dec 2008
    Default Boost Gauge
    Hey guys, i have bought myself a supercharged vy calais and i am trying to find where to connect up a boost T so i can run boost gauge. ive tried a few different hoses, but hey all seem to be in vacume even when engine is boosting. any help would be great, and maybe a pic
    Thanks guys
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    dunno alot about superchargers but wouldn't most of the vacuum hoses also be boost ?? i know on a turbo car you can attach a boost gauge to almost any vacuum line.
    Best bet would be your vacuum line off you fuel pressure reg as that has to run boost to get the pressure to change. (not sure about the end of that sentence)
    Dec 2008
    VYS6 is offline Standard- For now...
    VY S Pack V6 S/C
    Aug 2008
    Best place to run the factory supercharged gauge from is the LIM (lower intake manifold) there is a rubber grommet over a single ridged nipple that if im not mistaken was ment for hooking up a boost gauge or a remote map sensor. It will give you the actual pressure in the intake as opposed to a vaccum line running off the bypass valve which may read high. The black grommet is ont eh front of the lim just under the pulley for the supercharger.
    Thats where i run mine and now that the plastic hosing has hardened slight it shows around 5psi at WOT above 3grand. just need to make myself a pulley puller to get my 10psi pulley on now :P
    VY, S supercharged 2003
    Dec 2006
    Quote Originally Posted by VYS6 View Post
    Yep, thats where I'm running mine from. Runs perfect. I even did a custom gauge pod for my car since the original were way to expensive and didn't look as good.
    VY S Pack V6 S/C
    Aug 2008
    Nice Custom job XXFR. Mind telling me what you used to mould the cup etc? Ive just got mine in the corner of the dash attached to a adhesive pad atm but its pretty noticable. had a cop pull me over for a bretho and he never said anything at all. but would rather it be secured so it doesnt get flogged or anything
  1. Auto Gauge 2"/52mm Smoke Series Boost Gauge w/ FREE gauge cup
    By pepstar87 in forum Parts And Other Items For Sale
    Last Post: 16-05-2008, 01:16 PM
  2. boost gauge
    By vs_commodore_s in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2007, 01:18 PM
  3. Boost Gauge
    By XXFR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-04-2007, 02:02 PM
  4. Boost Gauge
    By XU6 (fLOGINU) in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 06:40 PM
  5. Wtb:- Boost Gauge
    By V6VL in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2005, 02:22 PM
