Hi I have just purchased a VY Berlina and i have a quick question i am unable to find anywhere in the mode section in regards to the alarm I have locked the car and tried opening a door and nothin happens as the doors are dead locked it there any way of checking if it has a alarm as it is meant to have one?
Also is the car meant to have dual cliamte control as i can only seem to get the single temp display on the screen instead of two.
I alos believe the previous owner has installed this own fog lights or driving lights on the car but when i got it there was no holes in the front bar for them is there a way i can change the black insert to acccept them
lock the doors but dont deadlock them and have ur window open a bit. then stick your arm down and try lifting up the doorlock. or lock your doors and open your boot. That should get it mate.
Dont know about your climate control.
If he did have foggies on maybe he pulled them out and put back in the black covers back on. try pullin off the covers and you might find some wires sitting there taped up from where he took them off. if thats the case buy yourself a set of holden foggies and plug and play.
Hope this helps
Thanxs mate I will try the alarm when I get home tonite, I have found the wires this moring they are there just no fogies. I cant remove the black bit as it is one long black piece in the Berlina not the same as in the other models where there is two black covers on the ends Also the buttons does not pull out for the fog lights
****. maybe he had in a seperate switch for them. Im not really sure about the berlina fog lights mate, maybe someone with a berlina can help out but if the wires are there wouldnt it be just be a matter of rippin off that old black trim and replacing it with one that has the fog lights or at least the fog light holes in it
I have rang a holden wrecker and the front bar for the Berlina with the fog light holes is like $200 unpainted. Will test when i go home plug a light into the wire wire plug and see what happens
lol its not a dual climate control, one side adjusts the temprature by 1 degree and the other blue and red button pushes the temprature to the max or minimum.
As for the fog lights u can buy a lower grill insert for ur car with foglight inserts for $170 bucks, it is the long black piece with 2 holes
Thanxs mate i though that was the case better to check these thing out do you know where in sydney I can buy this piece from?
i found the eaisest way to check the alarm was to lock it with the remote not dealock wait 5 secs and unlock with the key and than it goes woooo wooo wooo
dual climate is for higher spec models another bull**** thing the dealer says to try and make a sale
they advertised my old berlina as a series 2 with dual climate and a few other non existant features.
you can get that fog light thing from any holden dealer, i did this upgrade to myne but didnt get around to having it wired, there is no factory wiring loom in the series 1 for fog lights.
ps. not a whole lot of clearance when installing the fog lights either so be prepared to waste a bit of time trying to line it all up without breaking anything
Thanxs for all the good replys
hey evil_Monkey I have all the wiring already done by the previous owner all i need to do is buy the grill and the lights and plug it in but i dont have a switch so they will be always on thyanxs for the advice![]()
any holden dealer sells them, u just gotta cough up big $$$$
good luck buddy ive tried everywhere.
yeah i coughed up the 500 odd cause i couldent get any from a wrecker
wanted it to look the part as it was beeing used at my wedding.
oh by the way that long black plastic thingo if you are good with a dremel and do carefull measurements of the bezels that can be cut, thats all the new peice is the same bit but with holes cut in it
I found a guy in Sydney who sell the whole front with grill un painted for $200 with out the lights he reckons it is genuine holden but i am not sure got to have a look on the weekeend
thanxs man i am alrite but one might end up bigger then thew other lol
And to think I sold the lower grille from my VY Series 2 Berlina for 40 bucks on e-bay a couple of months ago.......
