Results 1 to 15 of 15
Thread: Grinding noise when taking off & steering...
    Mercedes C200K AMG-Sports
    Mar 2007
    Default Grinding noise when taking off & steering...
    I noticed two things with my new [to me] WK V8...
    1. When taking off with the drivers side window open, I can hear a quick grinding noise sometimes coming from outside... could it be the breaks?
    2. Also when I steer around a tight corner or park the car, there is some kind of rubbing noise coming from the steering the the steering wheel starts shaking... could this be because I'm not used to driving a large car?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    i would say warped disks if the wheels start shaking.
    eliminate the problem by having the rotors machined and new pads fitted.
    Mar 2007
    Quote Originally Posted by Ozzie View Post
    Sweet! I'll call the dealer to do that when they service it tomorrow... hope it doesn't cost much. Anyways, we got a good deal on the car so if we HAD to spend a few thousand to get it ship-shape its still a great car.
    Mar 2007
    I got this done by holden (needed brake pads anyways) and the noise is gone but the shacking is still present. When I turn the wheel at stationary it shudders pretty crazy. When I drive there is a vibration.
    I took it to a mechanic I used to use for my old Commodore and he took it for a spin. He says a power steering fluid fush may help the shudder. He says the shacking may be due to the car sitting in the previous owners garage too long and the tyres may have developed a flat spot.
    They are pretty busy and I got it booked in on the 10th Jan for them to have a look.
    Any comments from you guys would be appreciated
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    There was a problem with the PS hose on some VY's. There was a techline on it. They will replace a hose section i believe, and clamps onto the rail.
    Cant remember exactly, but if you go into holden and explain the symptoms and the car is within the range of VINS they should be able to fix it for you.
    Also on takeoff, i think the ABS will give a bit of a calibration noise that can sometimes be felt.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Mar 2007
    Quote Originally Posted by BLK-SAB View Post
    What is meant by 'range of VINS'?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Between one VIN and another. The VIN being vehicle identification number, found on the silver plate at the base of the windscreen on the passenger side.
    The shuddering sounds like power steering, a flush and new fluid will probably help it.
    Visit my Facebook page
    Mar 2007
    Quote Originally Posted by Not_An_Abba_Fan View Post
    So how will giving the VIN to my Holden dealer help? (sorry, I'm not a car guy but like driving my holdens)
    The steering flush is what my independent machanic recommended and will do come the 10th Jan. I'm glad someone else confirmed this, thanks mate
    Sabbath''s Avatar
    Jul 2006
    The techline procedure which Holden recommend to fix the problem of Low speed steering shudder is to replace the HIGH PRESSURE hose between the Power Steering Pump and steering gear with a revised hose. The revised section is longer and is routed along the front of the engine and mounted in place with two clamps.
    Your dealership should be able to help you out if you phone them up just, probe with questions as to whether other cars have had problems with shuddering steering. There is a techline on it, so they should know of the problem and be able to fix it for you.
    Mar 2007
    I'm gonna suggest this to my mechanic. The owner used to work for holden. I kinda trust them more with my car. I had holden service the car last week and told them about the shudder. But they didnt do nothing or suggest nothing. They said the speed issue is the tyres. I wrote them a letter of what was wrong with my car (I couldnt drop it off myself) and the guy didnt even read it until I called him. My mother dropped off the car at 9am and gave them the letter, they didnt read it until after 1pm after I had to call them.
    I just feel like a number when I bring my car to them, not a customer.
    Your a big help my friend, thank you.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by anonymousmoose View Post
    If your VIN falls between the VIN's that have the problem hose, then they will fix it.
    VY SV6
    Oct 2008
    Default Noise when turning
    Hi, I had this problem and it was solved by replacing one of the power steering hoses, it was a design fault. It was like a water hammer effect when turning on full lock.
    Mar 2007
    For free (as a recall)?
    Also, I pumped 2 PSI more into the tyres then I am supposed to and the steering feels better today. I didnt drive it on the freeway but at 80km/h its better then before.
    Sabbath''s Avatar
    Jul 2006
    What sort of PSI do you have them sitting on at the moment?
  15. #15
    Mar 2007
    36 all four; they recommend 34 (if I remember correct) for the front and 36 for the back. I just drove on the freeway tonight, it was a bit smoother and less shake but I only drove about 4kms so its not the best test.
  1. grinding noise....:(
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 12:15 AM
  2. grinding noise
    By ned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-02-2009, 11:06 AM
  3. grinding noise at start-up.
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2008, 01:32 PM
  4. bad Grinding noise
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 07:51 PM
  5. VS V6 strange grinding noise.
    By Attakarrak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2006, 07:59 AM
