Hi everyone,
Wondering if anyone could shed some light on my headlight problem...
I have it always switched to auto (yes i'm that lazy i don't want to turn headlights on or off). Up until about 3 weeks ago when ever i locked the car the lights switch off.
They now no longer do that, i now have to unlock my car and then relock it for them to switch off. This is guarenteed to happen everytime.
Thanks![]()
When starting up your car goto the option menu (press up or down like the screen says to) and cycle through the options. I can't remember the exact name of the option, but it should say Headlight in it. Set that to 1 second. Not sure if that will fix it but that's the only thing i can think of off the top of my head.
I think i've done that before - its on 2 seconds now (i think)
i'll give that a go though. thanks for the suggestion - i'll let u know if it works
Yeah, I'd give that a try Tim - even if you set another delay option - or turn it off altogether - and then re-enable it with your preference. It might be that the config has its knickers in a knot about something.
Failing that, I'd maybe look at taking it to Holden - it might need a reflash of the BCM.
Another thing to try is to disconnect the battery for half an hour or so - means everything has to go through a full "reboot" when you connect it back up - that can help clear oddball issues.
Good luck with it!![]()
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
