Can anyone tell me how i can make the light in my centre console work? just installed it and its not working! Everything seems to be plugged in the right spots and the cig lighter is working, how come not the light...?
check to see if you have power with a test light, if you do then the globe is blown if you don't then it is in the wiring or the switch.
no power, could it be a fuse because wiring is pretty straight forward, only two wires? or is there a catch!?
one will be power and the other will be earth, check the fuse, if it is not blown then it is your wiring.
ok so which colour is the earth wire?
Jessie...x
