Results 1 to 9 of 9
Thread: help diagnose my climate control problem pls?
    gottavecalaisv's Avatar
    gottavecalaisv is offline Calais' are great mate!
    Ve Calais V V6
    Jan 2007
    Default help diagnose my climate control problem pls?
    Hi all, i have a VY Calais supercharged V6 with dual zone climate control and today we were driving in a 100km/h zone with the climate control on and also cruise set at 100km/h as soon as we came to a slight hill or steepish hill the car kept constant speed but the iar con stopped blowing air from the face vents and blew air from the front demist vents only. this all went back to normal when the road flattened out again but happened agaion at every rise in the road? could it be a vacuum related problem? if so where do i start to look for the problem?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    There has been another thread on this matter recently. The fault has something to do with the vacuum control valve in the air con under the dash. Check the Electrical or Air-Conditioning forums to pick up the thread.
    vy belina wagon 5.7
    Jan 2009
    Default same problem
    Just wondering if you have had any luck on finding the source.
    On these hot days it drives you mad.
    Any help would be appretiated, i tried to look elswhere but had no luck.
    thanks tezza
    Ve Calais V V6
    Jan 2007
    no luck from me, i rang holden and they said it could be one of a few things so will ask next service to fix it.
    03 VY Berlina S1
    Jan 2007
    this has been discussed in the vt-vx section, i have the same issue you need to remove the right hand panel open the fuse cover and there are two little screws which you undo and the panel closest to the centre console the lower comes off and the and the white cylinder is behind the radio check the vacum thing it is a white plastic cylinder and also behind the glove box their are hoses and other stuff to check but i have not had time to check this myself yet
    Ve Calais V V6
    Jan 2007
    i have seen the two white things but don't know which if either are playing up. Holden even said it could be the BCM??????????
    vy belina wagon 5.7
    Jan 2009
    THanks for the replies, maybe you can try and give me some info after you have been to holden.
    i am sure it has to be something simple to do with the vacume.
    Thanks tezza
    Ve Calais V V6
    Jan 2007
    VY SS 5.7 ute
    Feb 2009
    hi i have a VY SS 5.7 ute it has a problem where it will only blow air out the windscreen demistter and its the same whether the car is running or not and i checked for vacum on the back of the swithces and there was none so i pulled the engine cover off and checked the hose comming thru the fire wall and it was split so that was how i fixed my car hope it helps. also there is a vacum controll bottle that cracks its located undre the bonnet near were you fill up the window washer fluid if it cracks you will need to replace it also the reason the car goes to demist is due to that being the default setting
  1. Climate control problem
    By mildewmatt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2008, 12:33 PM
  2. Diagnose my gearbox problem for me :)
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2007, 09:44 PM
  3. VP climate control problem
    By joebloggs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2007, 12:24 PM
  4. Climate Control Problem
    By brad_m_is in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 11:16 PM
  5. Climate Control Problem
    By dmbillo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2005, 09:37 PM
