Results 1 to 5 of 5
Thread: SRS Side Air Bag - Location?
    2004 VY Acclaim Series II
    Dec 2007
    Auckland, New Zealand
    Question SRS Side Air Bag - Location?
    Does anyone know where the side air bag on a VY Commodore is located?
    Assume they're either located behind the plastic panel on the rear of the front seats, or more likely the panel of the doors...???
    Also is it safe to have rear facing car seats installed? Particularly if the side air bags are located in the front seats, and the rear facing seat is up against the front seats...
    VY2 Berlina
    Jun 2008
    Castle Hill
    side air bags are in the sides of the front seats. 2 in each seat.
    I'd assume then that having anything other than a adult in the front seat is a bad idea
    Dec 2007
    Quote Originally Posted by cewing View Post
    Thanks for that... Assume they inflate to cover the windows? one forward one back?
    Sorry, I meant is it safe having the rear facing car child seat in the rear of the car immediately behind the drivers seat (child seat touching the back of the drivers seat)...
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    It should be quite ok for the child seat to be placed as you want. The side air bag inflates to fill the gap between the driver and the door and pillar. All the inflation takes place towards the front of the seat, none of it intrudes into the rear passenger space.
    It doesn't cover the window - that only occurs if you have curtain air bags, which weren't available in VY's.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    They are located in the bolster on the top half of the seat and they deploy towards the front and up
  1. car amp location ????
    By creamy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-06-2008, 07:06 PM
  2. PCM Location for VS?
    By Tomwally in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2008, 11:06 AM
  3. Vr Side Moldings Haw R Thay On? And What Side R
    By Damian_w42 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2004, 05:47 PM
Tags for this Thread
