Results 1 to 3 of 3
Thread: cruise control won't turn on
    Clay-VY's Avatar
    Clay-VY is offline Clay
    VY supercharged Calais
    Sep 2007
    Default cruise control won't turn on
    has anyone had a problem with the cruise control not turning on?
    VY Commodore S Ute
    Sep 2007
    Have a look to see if you either have blown brake light bulbs, a blown fuse, or LED brake lights. The cruise control needs to see the 'earth' via the brake lights. If the bulbs are blown the cruise just wont turn / stay on. If you have LEDs you will need to fit 'load resistors' to the brake light circuit.
    Clay-VY's Avatar
    Sep 2007
    Thanks for the info, unfortunately all lights functioning and fuses intact. load resistors are fitted, it was working perfectly prior to going in for a service!!!
  1. traction control and abs light wont turn off
    By johnno010684 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2008, 08:23 PM
  2. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  3. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
