Results 1 to 10 of 10
Thread: Horn just stopped?
    rippen50's Avatar
    rippen50 is offline Wants a Manual =]
    VY Executive 3.8L
    Apr 2007
    Camden
    Default Horn just stopped?
    As it says in my VY exec my horn just stopped i held it in for about 10 seconds than went to press it again and it didnt work????? any help cheers
    VY monaro
    Nov 2008
    Wheelers Hill
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    rippen50's Avatar
    VY Executive 3.8L
    Apr 2007
    Camden
    Jbird: some how the alarm does work it went off today...
    hakhawk: i did i changed it and still not working... i might double check thought just to be sure
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    If your alarm works then it sounds like the "switch" is the problem. Time to take off your horn and check that it's grounded and all wires are plugged in! And the horn makes contact! xD
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    My VP has a seperate horn for the alarm, so i'd assume they havn't changed their setup, so it doesn't sound like that.
    If could be the plug that earths to the steering column.
    What or who were you beeping at for 10 seconds?
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    rippen50's Avatar
    VY Executive 3.8L
    Apr 2007
    Camden
    Quote Originally Posted by STEALTHY™ View Post
    I got cut off and almost crashed so yeah.... i won't be doing that again =[
    Nov 2008
    Tullamarine, Vic
    I'm fairly sure the VY's have 2 horns but are both linked by the 1 relay which the horn and the BCM have access to using [according to the wiring diagrams]. If the Alarm works and the Horn doesn't then it's a fault with the Horn, if both dont work it could be the relay or both horns!
    VY monaro
    Nov 2008
    Wheelers Hill
    u need a new horn, easy fix same thing happend to mine, it shorted from the saftey sticker behind airbag and blew the horn, it by passes the fuses thats why its dead
    rippen50's Avatar
    VY Executive 3.8L
    Apr 2007
    Camden
    so u reckon just wack the air horn in now?
  1. my speed o has stopped
    By mradam1986 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-08-2008, 09:30 PM
  2. My key stopped working.. :(
    By Howks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2008, 11:52 PM
  3. She just stopped
    By Dayvo in forum General
    Last Post: 23-05-2008, 04:09 PM
  4. Replies: 3
    Last Post: 03-02-2007, 09:51 PM
  5. Odometer Stopped
    By Emackulation in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2005, 05:01 PM
