Results 1 to 8 of 8
Thread: LPG Injected, First service.......
    VYII
    Oct 2007
    Default LPG Injected, First service.......
    Have a VY V6 c/w LPG Tartarini Injected Gas is due first for its first service 20-25,000 k's
    Anybody have an Idea of whats involved in the service, and what's the likely cost?
    I assume they will check for leaks replace the spin on oil type gas filter.
    Is fuel map re-checked as standard practice, and seals replaced?
    Still getting exceptional fuel economy, latest was 71.50 lt's @ $24.23 receiving 680klm normally get 640-700. Have recently changed from castrol edge to Nulon full synthetic 10W40 with suprising results.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Yes, they pretty much check for leaks, and they re-tune it with the pipe up the arse trick (mixtures). Do the injected have a gas filter ? Interesting.
    VY Calais V8
    Jun 2005
    All injected gas cars have gas filters before the vaporiser. It should only cost ~$50 - $100 to have it done, check for leaks, replace filter and check (and touchup if needed) tune. Shouldn't take more than an hour to do either.
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    VY Calais V8
    Jun 2005
    I'm not sure, i know they're required on the injector kits to stop gunk clogging the injectors.
    Jul 2006
    no they are not required as the miex feeds through the throttle and intake etc.
    VYII
    Oct 2007
    thanks for the heads up!
    Just on the filter, looks like a black ryco Z386 oil filter , which sits before the vaporiser like danielsan mentioned.
    Getting 650 to 700 ks per tank but I think I might request the fuel map to be changed, as I want more take off power.
    Feb 2007
    There are two types of LPG conversion.
    1. Single-point including venturi and air-valve systems.
    2. Multi-point including gas injection and liquid injection systems.
    The injected systems do have a gas filter, but that lasts for well over a year's worth of driving normally. After a year's driving, your regulator will have well and truly settled in so a retune will more often than not improve things such as idle smoothness.
    On mixer-based systems, a retune every year is almost mandatory.
    Regards,
    Dave
    Injected CNG, LNG & LPG: The only way to go better!
  1. SV6 service vehicle soon 8000Ks after service/repairs
    By Cyaegha in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-07-2008, 10:33 PM
  2. injected vh ???
    By bitch in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2006, 07:42 PM
  3. Injected VH SLE
    By starkie85 in forum VB - VC - VH - VK
    Last Post: 02-10-2005, 10:52 PM
  4. 253 injected?
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2005, 08:09 PM
  5. Injected 5.0 VL?
    By vlv8vic in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-03-2005, 05:33 PM
