Results 1 to 5 of 5
Thread: OTR for V6
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default OTR for V6
    When there's all this talk about 2 hole mods and CAI's for our v6's, has anyone ever tried to fit one of the v8 OTR filters to a v6 and pipe it straight to the MAF sensor?
    I'm thinking i might give it a go.
    I know it makes the car instantly defectable, but the v8 lads don't seem to have much of a problem, Plus i haven't given much thought of what you'd do with the little sensors in the air box - probably drill a hole in the side of the OTR?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY II SS
    Sep 2008
    From memory, I think there was no noticeable power difference between stock and fitting an OTR to a 6. hence why no companies I think make them much for the 6.
    They work well on an 8, but I think the 2hole mod costs $500 cheaper, for more gain.
    Mar 2008
    i think MAYBE if you got a custom one built with a 120mm pipe running through the MAF then splitting into a twin throttle body setup might work i think, but even then you'd still have the problem of the 60mm restriction of the MAF.
    Either way you're right - it's going to cost billions...
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    Mar 2008
    1.3 years buddy, then i'll decide if i'll play the V8, SC or TC game
