Results 1 to 7 of 7
Thread: Noisy drive belt pulley
    VY Executive
    Jan 2009
    Default Noisy drive belt pulley
    when I start my car ....until the engine heats up I get this high pitch noise from a drive belt pulley...what can I do to resolve this issue?
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Is it like a squeak? I thought it was my supercharger pulley, so i wd40d it and some dropped onto the other drive belt and made it worse, but once it got over it it was all good and the squeak still remains. While the engine was running i then loosened the pulley adjuster with a spanner to check, turns out it's one of my belts (before it even looked like it was crap). My drive belt now is starting to fray, i just need to get around to ordering the racing belts!
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    yep i go the squek too, its the idler pulley, just replace her or spray her.
    VY Executive
    Jan 2009
    VS l67 statesman
    Dec 2008
    my l67 vs statesman suffers from the dreaded cold squeak too ,Ive tried spraying it with wd ,using htb grease ,but its still with me on start up,just not as bad as before
    I hope some one comes up with an Idea on how to lubricate sealed bearings
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    will have to replace the idle pully... i got the same prob
    Going where no late model stato/caprice has gone before.... GAME ON!!
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    Some of those pulleys when you take them off theres a small bearing pressed into them. Just press it out and go to CBC and take it as a sample. Press back in and your away. If its just the belt WD40 drys out, you need some drylube. Supercheap should stock it.
  1. Noisy/Lubricate Fan Belt HELP ?????
    By ac2026 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2008, 02:46 AM
  2. Noisy Pulley?
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2008, 09:46 PM
  3. Idler Pulley noisy?? & Brushing noise from alternator
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2006, 08:15 PM
  4. replacing bearings on Drive Belt tensioner Pulley
    By turkeychicken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 01:23 PM
  5. WHATS BEST WAYTO change drive belt tension pulley on hsv LS1 V8
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2006, 08:41 PM
