Results 1 to 6 of 6
Thread: Oil In Water
    VY Berlina
    Apr 2007
    Default Oil In Water
    Posting this on behalf of a local mechanic friend. He has a VY S V6 and it's getting oil in the water, it's engine oil as the engine oil level gradually drops. The WHOLE engine has been stripped and rebuilt to try and fix this but it's still doing it. The only thing that wasn't done was getting the block crack tested or sonic tested as the local shop said trying to test all the oil galleries in the block would be near impossible. Has ANYONE come accross this before with the Ecotec V6's as we are stumped.
    Cheers, Jeff.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    im guessing the block was decked?
    if everything has been done correctly, and its not blowing head gaskets, there either a crack in an oil gallery between coolant and oil in the head or block,
    it would be rather unusual if it did though
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    it's not the wallnut pellet's is it ??
    they give the aperance of oil on the radiator..
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VY Berlina
    Apr 2007
    We are picking it's a block problem, but are interested to know if anyone has come across it before. It's definatly engine oil as the level is dropping. A new block here in NZ is horrendously expensive and trying to find a good 2nd hand one is near impossible.
    vr 3.8l manual
    Jan 2009
    livverpool
    vy ss commodore 5.7ltr
    Jul 2006
    sounds like the bore liners might be leaking, seen this on engines before, replace the head gaskets thinking its just a blown head gasket, only to find out its the liners of the cylinders leaking at the top of the block, you can test this when the heads are off and the gaskets off, buy blocking of any hoses that aren't conected to the block that would have been connected to the heads and metal plates sealed onto the block with like a 3bond sealent over the coolant galleries at the block, one of these plates will have a tyre valve in it which you pump up and if the liners are gone it'll leak out/weep out, if easier may have to give to a machine shop to test the block, we had special ones at the dealership i worked at for the v8's (land rovers though) also seen the liners move on 4 cylinder engines too.
  1. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  2. water
    By ab56452001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 11:23 PM
  3. Run your car on water?
    By commodore2004 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-06-2008, 06:08 PM
  4. car covers . water proof vented vs water resitant non vented
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2005, 01:20 PM
  5. Water in Car
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2004, 05:41 PM
