The local mechanic put a set on the ute for me today, and apparently they were too short compared to normal extractors. would there be any purpose in this, or is the mechanic just whinging? Also worth noting is that he had to bend the pipe that houses the IAG (?) sensor in the extractors so it wouldn't be resting on the engine.
Looks to me as if they might be a bit cheap.
I didn't think redback did extractors untill i was getting some work done and the guy said i should get a set of them instead of packmakers. How much did they charge for redback headers? they wanted $700 fitted for a set of pacemaker
From everyone that has Redback exhaust systems they say they're not cheap crap! They usually swear by them saying theyre much better than imported stuff because it's made for our conditions and laws (USA's exhaust laws are different apparently).
still swear by my redback catback and hoping to get a set of redback extractors aswell let me know how they go...
$700 fitted for a set of Pacemakers?
I got quoted $1400 from Sureflo for a set fitted.
I however opted for the modified HSV extractors and cats which flow just as well.
Thats what I mean, it was $1400 fitted JUST for the extractors, and $600 for cats.
I do have their 3.5" catback system though.
They finally finished putting them in today - i think the mechanic charged me $300 for the extractors but i'm yet to get a bill.
Having said that they're cheap, they obviously worked - just outside of town (on private property) there's a small straight which i used to be able to clock 100km/h from standstill. Just checked now and i hit 120 in the same spot!
I did however get the extractors installed PLUS a 2.25" twin setup on top
The exhaust shop where i got my extractors fitted recommended the Redback extractors.... i initially was asking for pacies as all i saw and read about were pacemaker extractors .... The shop would of ordered some pacies in but i decided to go with the redback (the owner of the shop uses them on his Supercharged project car which was good enough for me).
Bloke reckons his latest dyno run comparing the pacemakers with the Redback had the redback allowing more rwkw. After coming down off all the hype of having a set of """Pacemakers""" i am happy with the Redback's.
All this is for a stock V6 though....
Honestly mate you got ripped !!! How much was the HSV system ???
I have got 3 different quotes of up to $780 fitted for Pacemaker extractors cermiac coated inside and out for my VX. The highest i saw were Hitek Headers, which fair enough are custom made stainless, so they are dearer.
skooby's is an ss so the gen3 headers are a bit more and fitting costs are a bit more again than the v6's.
the pacemakers for a gen3 are 700-1,000 alone plus fitting on top, i got quoted 1,200-1,500 for pacemaker and x-force headers fitted from a couple of places, so sounds bout right.
