Results 1 to 4 of 4
Thread: Vy ii antenna arial
    VY Executive S2
    Apr 2008
    Default Vy ii antenna arial
    Hi Guys, wondering if anyone can help me. When i turn of my car the antenna comes down sometimes half way sometimes all the way then goes back up and radio turns on. Its a pain in the asse because i sometimes lock my car and go only to find my radio on when i return. Do i need a new antenna. Has anyone experienced this problem.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    So your head unit is on when you come back to your car? Sounds like either your mode button on your steering wheel is broken somehow :S Or your On button can activate itself! Have you tried removing power from the car for 15 minutes to give it a reset (might work, fixed my CD issue)? It sounds more like the On button on your head unit is stuck on! It's definatly not the antenna's fault, it just does what the head unit tells it to do.
    VY Executive S2
    Apr 2008
    Nov 2008
    Tullamarine, Vic
    Just remove the negative wire on the vehicle's battery for 15 minutes.
  1. Arial
    By HoldrodeoLT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-08-2008, 08:37 PM
  2. getting to the arial motor
    By System in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-08-2008, 07:00 PM
  3. VP Arial? Stays up?
    By benjiaka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2007, 01:36 PM
  4. Arial Replacement
    By jabbavx in forum Car Audio
    Last Post: 24-02-2006, 02:39 PM
  5. VQ arial
    By yotaman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 04:29 PM
