Results 1 to 6 of 6
Thread: Where is the Bleed screw?
    VK Commodore
    Sep 2006
    Default Where is the Bleed screw?
    Hi All, Just wondering if anyone knows where the bleed screw is on a VY V6?
    Thanks in advance
    VT
    Apr 2005
    QLD
    Quote Originally Posted by Phantom VK View Post
    Thanks in advance
    Sitting vertical in the thermostat housing.
    It is a gun drilled screw, so you only need to screw it out past the pilot hole.
    It will make a mess.
    VK Commodore
    Sep 2006
    Thanks for that, I was pretty sure that's where it was but wanted to check before I took all the plastic covers off.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    If it's supercharged its actually got 3 bleed screws from memory. 2 at the front and 1 at the back of the supercharger.
    VK Commodore
    Sep 2006
    vs acclaim II
    Jan 2009
    might be quite a daft question but i'm not much of a mechanic.... i have just replaced the top hose on my vs acclaim 1997 (radiator) and filled it all up again. running fine and fan kicks in at about 2/3 up the heat gauge and brings it to about half. do i need to bleed the system now though? and if so do i just get it idling and slowly undo the screw on top of where the top pipe meets the engine?? will it just fart a bit if theres air in their?? how do i know when it's done?? thanks j
  1. correct way to bleed vn v8 radiator
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2008, 03:36 AM
  2. bleed nipples
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 07:41 PM
  3. bleed valve
    By jippa3000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2006, 07:46 PM
  4. where is the bleeder screw to bleed the radiator
    By vl rb30 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2005, 08:37 PM
  5. Make it Bleed
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2005, 04:37 PM
