Results 1 to 23 of 23
Thread: VZ Fluted guards on a VY SS
    lastlegend's Avatar
    lastlegend is offline Phantom VY SS
    2003 Black VY SS + 1999 Silver VT Olympic Sedan
    Sep 2008
    Thorneside QLD
    Default VZ Fluted guards on a VY SS
    Hi all,
    I would say that this has been asked or covered somewhere on the forum but could someone tell me if the VZ SS Fluted guards are the same as the VY SS guards before I order a set off VZ guards to fit to my VYSS.
    I have a set of HSV Flutes I was going to get my panel beater to fit up but he has suggested I get a set of VZ Fluted guards as it will make the job a hell of a lot easier.
    Any help would be great as I have been told there maybe slight differences in the two guards - besides the obvious cut outs for flutes hehehe.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I'd be surprised if there were differences, but can't say for sure.
    Either way though, can't be that hard to cut a hole in the guards and stick the flutes in there can it? Sure would be cheaper I'd think...
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    i was just looking on ebay for someone else that wants to do this for their VZ and its cheaper to buy the gaurds with the holes already cut in them.
    the flute templates that you weld in are $330 plus the fultes themselves.
    a gaurd can be had for less than $150 with the hole already done.
    not sure either if VZ and VY gaurds are the same.
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    Yep, I looked at the same options and buying the guards is a better way to go but just need to confirm they are the same before I push the buy it now button?
    FG XR6T Ute manual
    May 2007
    Brissy
    Im 90% sure that the angle where the headlights meet the qtr panels are different meaning they won't fit. Check some side on photos of a vy and a vz to see the angle
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
    Nov 2003
    Warrnambool
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    The simple way to work this out is to find out if the standard, non-fluted VZ guard has the same part number as its VY equivalent. The only place they would vary would be the headlight opening - all other adjacent panels use the same mounting points and have the same shut-lines.
    If the standard VY and VZ guards have the same part numbers, then the VZ SS guards will be a bolt on.
    So, has anybody fitted a standard VZ guard to their VY, or vice versa, or does anybody have the part numbers for the two models?
    FG XR6T Ute manual
    May 2007
    Brissy
    compare the angle of the headlights
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    vy ss commodore 5.7ltr
    Jul 2006
    as far am i am aware its the bumper section that is different due to the headlights being different i.e the vy having the parker at the bottom and the vz being straight at the bottom.
    yeh would be a lot cheaper to buy the gaurds.
    that vz looks sick, iv seen a black ve recently with the same dragon on it and dragon badges instead of holden badges around the south east suburbs.
    Nov 2003
    Warrnambool
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    Well I jumped on Holmart and got a reply, they make the VY & VX guards with the flute cut out so I have put up the cash $150 per panel and will see how they fit up on my VY SS.
    I will post some images once its been done, also picked up a set of VZ HSV R8
    Twin Finn flutes with indicators, globs & looms to fit to these guards.
    Thanks for all your help and comments, it kinda time to fit and see what happens.
    GRUNTS's Avatar
    GRUNTS is offline GRUNTS
    BLOWN,VY R8
    Jan 2009
    Moranbah QLD
    i fitted VZ guards to my VY R8, so yes they do fit, the guards are exactly the same just VY guards dont have the cut out for flutes
    VY, S supercharged 2003
    Dec 2006
    Been there done that. I installed the VZ flutes on my original guards. They look great in my opinion.
  15. #15
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    Just finished chatting with my panel beater and the car will be ready to pick-up tomorrow....
    Work I have had done:
    VZ Guards with HSV R8 Flutes
    Evo style Bonnet scoop ( slim line version of the new Walkinshaw scoop)
    New custom made Grill with Mesh ( no lion or centre bar) increased air flow to CAI Bigmouth kit
    New lower custom made Grill intake with Mesh.
    I will post some images up tomorrow once I pick it up....
  16. #16
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Quote Originally Posted by XXFR View Post
    How is the finish when you do this? Rough edges?
  17. #17
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    How did you mount these to your original guards? did you use the template or some other way?
  18. #18
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
  19. #19
    VY SS
    Feb 2008
    Looks good man. Could you get us some more photos of the flutes? Also how did he install them... using a template and cut into your existing panel? Did he respray the whole panel again or just blend in the flutes.
  20. #20
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    I will post some more images tonight, I purchased VZ Guards and had the whole front end resprayed as they had to do the bonnet and guards anyway so I thought they might as well redo the bar due to stone chips.
  21. #21
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
  22. #22
    VY Exec N/A Auto
    May 2005
    Geelong, Victoria
    What did it cost you to get everything done? including parts, painting, fitting etc? and one the white vz with the dragon is that decals or painted on?
    1.91 rockers, 69mm throttle body, bmc panel filter, electronic shift kit, plenum spacer, manifold insulator, pioneer 7inch 6 stacker dvd player, 2*12inch subs- custom fibre glass boxes
  23. #23
    pjwooly is offline motorcityband.com.au
    VY2 SS brute
    Dec 2008
    gold coast
    Default photo shop
    Quote Originally Posted by cpbait View Post
    i think youl find that photo has been played with!!! am i right....?? nice work thou!!
  1. VZ Fluted guards question
    By lastlegend in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-04-2011, 12:24 AM
  2. Mud guards
    By batemada in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-01-2008, 08:47 PM
  3. F.s Vk Guards
    By BLOW6 in forum Parts And Other Items For Sale
    Last Post: 12-10-2007, 05:21 PM
  4. VZ SS Guards
    By XasKahn in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-10-2006, 10:53 PM
