Results 1 to 4 of 4
Thread: mods for v6
    VY Exec
    Jan 2009
    Default mods for v6
    hey guys
    i got beaten by a camry and a 40 yr old v8 so i wanna start modding the v6 for more power i dont know s**t all about engines so dont know were to start.
    im thinking exhaust(dunno wat type or what else goes with it), extractors, and lsd i not no much more.
    maybe ppl could say wat mod and est kw gained.
    Cheers!
    O yer S/C not an option atm.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    If you look down the forum topics in this section you'll see there's already a topic like this about a VY ute.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Just a couple things...
    1. The search button... its a great little feature... use it.
    2. If you know stuff all about engines... its going to get pricey... when i was doing my my old vx i did as much as i could myself.... saving heaps of cash... thus having money for other mods. Just keep that in mind.
    Anyway... here is a plan:
    Step one - Remove restrictions.
    The ecotec is held back when it has the factory intake and exhaust.
    Some tuned length headers and a 2.5 catback will help on the "out" while a decent CAI, wider TB and performance filter will help with the "in".
    Don't worry about the cats unless they are stuffed because unless your doing some serious work the stock ones will do the job.
    2. Make some more power
    Now the ecotec is breathing well, its time to get some more horsies under the bonnet.
    At the deep end you have a cam and heads... pricey... and at the shallow end you have stuff like Roller Rockers...
    In my case, i got some 1.95:1 YT RR and they made a considerable improvement.
    Though in your case, having a VY you need to check your clearances on the rocker covers, etc as they apparently got lazy with the casting.
    From here you can keep going.. but its an ecotec... your going to end us spending alot of cash on minimal gains... trust me... been ther done that...
    3. Get the power to the road.
    Now you have some extra power, you need to get it to the road effectively.
    Now although you may have gained some ponies up top.. your torque down low is still not going to be anything to rave about... a higher ratio diff will sort this out... preferably an lsd.
    Also, the transmission or gearbox need to be looked at now. I had a manual so a HD clutch was the way to go with a rigid flywheel... the dual mass holden used in the manual 5-speeds was great for a sunday drive... but useless is getting power down quick.
    At this point... your wallet is going to be considerably lighter... but you will be able to show up a few boys with more displacement.
    If you can find my old thread (Search SOLOW or HCV) you can have a read through... it details my shopping list and the overall outcome... which was 0-100 in about 6.8 ish :P
    Good luck with it...
    VY Exec
    Jan 2009
    cheers mate
  1. vxV6 mods,best mods to choose?help appreciated
    By benjamino in forum V6 Development And Modification
    Last Post: 11-06-2008, 09:51 AM
  2. re mods
    By Alitis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2008, 08:15 PM
  3. mods
    By 46matt46 in forum V6 Development And Modification
    Last Post: 03-01-2008, 11:09 AM
  4. first vn mods
    By makntracks in forum V6 Development And Modification
    Last Post: 13-03-2006, 06:48 AM
  5. are these mods possible for my VN?
    By Commodore_Chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2005, 11:48 PM
