+ Reply to Thread
Results 1 to 11 of 11
Thread: 2003 holden vy s pack lsd?
    holden commodore 2003 vy s 3.8L hothouse green
    Dec 2008
    Default 2003 holden vy s pack lsd?
    jus wondering i have a 2003 holden vy s pack (non supercharger) and i want 2 no if it is lsd or not ???
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash DUK13Y Executive
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Tyson23's Avatar
    Tyson23 is offline S-pack baby ;) Tyson23 Executive
    VY Series II S-pack Ute M5
    Oct 2008
    98% sure they are mate
    Got any pics of ur ride?
    Tys
    _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
    _ _ _ 2004 VY Series II - S Ute in ReD _ _ _
    vy s ute series II 2003
    Dec 2008
    im pretty sure the vy's s pack sedan doesnt come out in lsd unless you have it optioned, and unless its a ute only then they are lsd's easy wai is jst go under the car and check ))
    VY SS S2 Utility 2004
    Dec 2009
    Melbourne, Inner.
    you can check yourself, get under the back of the car and you'll see the diff, on it will be a metal dog tag looking thing that will say "LSD" if it doesn't say it then yours isn't an lsd, that also being said i believe that most of the lsds in the s packs are 3.08 (correct me if i'm wrong)
    livin' the low life.
    VY s m5 supercharged
    Aug 2008
    They didnt come standard so check if it has a tag on the diff, but if it has had new internals fitted then it might not havee the tag
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    Holden VS S Commodore
    Sep 2009
    tag should normally be on the housing of the LSD
    Quote Originally Posted by Jesterarts View Post
    With that logic, I want a cash incentive for every day I don't punch someone in the face.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    If its a LSD it will have " LSD" stamped on the Diff Oil Filler Plug tag. If its non LSD it will have "High Performance Diff" stamped on the Oil Filler Plug Tag. Also theres a Barcode plate on the Drivers side of the diff housing with the ratio & whether its "LSD" or not written above the barcode, (often obliterated by dirt & grime)
    VY04Calais is offline Banned VY04Calais Hitchhiker
    VY s2 Supercharged Calais
    Dec 2008
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by colgf View Post
    Not totally correct.
    I ordered my VY S pack car with the optional LSD.
    Yes there is a metal tag attached to the filler plug (rear of diff) and imprinted on the tag is: " LSD USE APPROVED LUBRICANT AND FRICTION MODIFIER"
    There is NO other LSD identifier on the diff that is decipherable to the owner.
    There is the usual ("do not remove") white bar code sticker on the driver's side of the diff housing but this does not indicate if the diff is LSD or not. On my diff , the sticker contains a bar code as well as the ID and SERIAL NUMBER codes together with the diff ratio and "FH" in large letters.
    Maybe the white stickers on some earlier diffs identified the LSDs but not on the LSD unit fitted to my VY (unless you can decipher the serial number or other codes). Just the metal tag is the identifier.
+ Reply to Thread
  1. 2003 VY II S Pack Utility (My Current Ride)
    By wazza 42 in forum VY - VZ - WK - WL - V2
    Last Post: 26-04-2010, 04:45 PM
  2. 2003 vy ss ute
    By Jakhama_2_mcmetz in forum VY - VZ - WK - WL - V2
    Last Post: 29-03-2009, 11:49 PM
  3. buying a 2003 HOLDEN COMMODORE VY Executive
    By mystera in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-12-2008, 05:08 PM
  4. Black VX II Supercharged S pack LOADS OF PHOTOS (My first holden V2)
    By Lloyd1986 in forum VT - VX - VU - WH - V2
    Last Post: 05-01-2007, 10:01 PM
  5. hot house green 2003 vy s pack ute
    By agrocm in forum VY - VZ - WK - WL - V2
    Last Post: 30-04-2006, 10:47 AM
