Just got a call from my mechanic saying that the shocks are on the way out and should be replaced. The car is 04 SS, with 92,000km on it. Has anyone else had to replace shocks, how long should shocks last?
Shocks tend to degrade progressively, and it depends a lot on how the car is driven and on what surfaces.
There isn't a hard and fast schedule like there is with oil, but it's quite possible that at 92,000 they are about due.
If you want a 2nd opinion you can take it to places like Pedders who do their "$14 28 point check" who will tell you the condition of your shocks (from memory they give you a print out with nice graphs on), or for a more simple test, park your car on a flat surface, then get out and push down on each corner of the car as hard as you can (the car body should move downwards), then quickly let go and the car will bounce back, if it bounces back more than once (ie up and down a bit) then they probably need doing.
If you take it to Pedders then I guarantee you that the "shocks are well and truly buggered". Bunch of liars. I'm speaking generally, there might actually be a truthful Pedders out there.
Ronald Reagan (1986)
Shockies only have an effective life of 40 000kms, according to Monroe, but I have found this to be pretty close. As said, shocks wear progressively and driving the car all the time you don't tend to notice them wearing. Fit a new set and you will feel the difference instantly.
92,000kms, i would replace them!
The Blue One
I have been quoted to get them replaced with GT Gas shocks, should i go with the gassies or just get the stock Fe2 put back in ?
The GT Gas shock is a replacement to the Fe2 shock. Thats wat i was told. I bought GT gas 4 my VZ SV6 yesterday, will install them on the weekend.
The Blue One
yeah doing some research they are same thing basically
Yup, Munroes are OEM on VT-VZ I believe.
I couldnt be bothered lowering the car, it corners much better than i thought, b4 i got it.
The Blue One
Lowering just opens up a world of issues on a street car - simply not worth it IMO. VZ's look fine at stock height.
Just wondering, should you replace all 4 at the same time? About how much shold it cost??
The Blue One
If the fronts have done 92 000 kms so have the rears, replace them all.
