hey all, on the way home from work today i had my fan going and all was cool in my car, stopped off at 7/11 to get a slurpee, when i got back into my car the fan would not work at all![]()
i have checked the fuse under the dash and it was fine, what else could it be?
if it is the fan how hard is it to get to in the VY's to replace?
40+ heat sucks without a/c in the car![]()
you mean the compressor fan or the interior fan?
the interior fan stopped working, when i drive i can feel the a/c still working as its got cold air coming through from the outside, but the interior fan just stopped working![]()
all the fuses under the dash that i can see i fine, is there any others for the fan?
if that's the case then check your wiring loom and connections if not your interior fan has died in the a** its not hard to replace its in the usual place under the glove box on the passenger side and i couldn't tell you how much a new one would be
EDIT: also check the fan for Debee or leaves jamming it up (if genuinely parked under a tree)
