Hey all just wondering what would cause the light on my ignition barrel not to come on and when i start my car it runs for about 2 seconds then stops i have to turn the ignition off push unlock again and start the car to have the same thing happen again? once you have turned the ignition once you cant fire it again unless you push unlock. i have disconected my battery for a day same problem tried using my spare key but still have the same issue any help would be much appreciated thanks!
check the ignition barrel globe by pulling out the black rubber surround. and as for the other ignition fault, i got no idea.
sounds like the key reader has come unplugged, pull it away from the ignition cylinder & check it
Rob
i checked the bulb its fine and the ignition reader is still plugged in so i was thinking maybe bcm?
