Results 1 to 11 of 11
Thread: VZ-VY Springs....
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    Default VZ-VY Springs....
    i bought a vy spack ute and the previous owner was a fata** or something and the drivers side is lower. if i put my stock springs from a vz sedan would it be the same as the utes normal height?
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    Adam_88's Avatar
    Adam_88 is offline soon to be boosted
    red VY Ute
    Nov 2008
    canberra
    VZ AWD One Tonner
    Jul 2006
    The utes definitely have IRS, but are different springs to Sedan.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Yeah I think the fronts might be the same, but the rears heavy duty? or something..
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    whats IRS? =[ so you guys wouldnt recommend it? too cheap to get lowered ones... just using till i get my airbag suspensions.
    Zeussy's Avatar
    Dec 2008
    Central Coast
    IRS= Independant Rear Suspension...
    Nah probly not, ask a local suspension joint if they are the same?.. they might know a bit more,
    You dont need lowered ones - its already lowered on one side! Just get the 4''grinder out and knock a coil off the passenger side.. lmao!
    Just joking, dont really do it..
    Air bags like load assist, for the rears, or the fully sick braa kind??
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I'm sure the utes have their own heavier duty spring settings for both front and rear. If the factory just upgraded the rear springs on utes, the suspension would be mismatched and handling would be affected adversely. As the rear springs are stiffer to take a load, the fronts would be slightly firmer than a sedan to ensure the handling was balanced.
    Putting sedan springs in would mean the ute wouldn't be worth much as a load carrier. That's assuming the rears would even fit - I suspect the utes would be shorter and stiffer and the sedan springs might not fit.
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by zeussy View Post
    like the ones u can raise up and down o.O..... yeah probly the "fully sick braa" one haha
    Quote Originally Posted by Calaber View Post
    i dont carry stuff would it matter if it fits?
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by Junny View Post
    I honestly don't know. Try it and see what it's like - you might find they fit both ends and you end up with a soft riding ute, if that's what you're after.
    BensVR's Avatar
    BensVR is offline BensVR
    VR ACCLAIM
    Dec 2008
    Peterborough SA
    lol good wrk
  1. swap vl springs for vr wagon springs
    By Sabby in forum Swap / Wanted to Buy / Trade
    Last Post: 04-10-2008, 04:42 PM
  2. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
  3. Shocks/Springs, Trapped Springs, how low?
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2006, 09:19 AM
  4. Has anybody ever swapped stock springs with SS springs?
    By vzuterus in forum General Discussion
    Last Post: 01-06-2006, 02:20 AM
  5. Swapping stock springs for SS Springs
    Last Post: 25-03-2006, 11:00 AM
