Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Traction Control
    914 is offline
    Sep 2004
    Default Traction Control
    Hi all,
    in the VZ, which models have the traction control switch?
    thanks
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Acclaim
    SV6
    SVZ
    SS
    SSZ
    Lumina
    Berlina
    Calais
    Statesman
    Caprice
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Feb 2005
    St Clair
    Can anyone shed some light to what traction control actually does.
    Off the mark & in the wet of course,if the traction control is on or off my car still goes side ways. I chased up Holden today to check if it's working & they are saying I don't have stability control to stop from going side ways, I only traction control which apparently cuts off power to the rear wheels.
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    I still get my car sideways in the wet, i try not to. It reduces power the wheel that doesn't have traction & applies it to the one that does.
    What i found if i was to turn left or right out of a street & gave it some stick, i can feel the back end step out but also feel the car lurch abit aswell & the whole car would become strait again.
    The Blue One
    Quoted for truth
    Feb 2005
    St Clair
    Quote Originally Posted by PaulSV6 View Post
    Cheers Paul
    Mercedes C200K AMG-Sports
    Mar 2007
    Mate of mine whos got a parliament house Berlina always turns his traction control off. Says he gets a smoother ride from it as the control kicks in too soon, even before the wheels start spinning. I sometimes take mine off and I do notice a little better acceleration.
    I thought all VY's have T/C... I might be wrong yet I thought it was across the board.
    VY2 Berlina
    Jun 2008
    Castle Hill
    I find traction control in the wet a godsend. my vy berlina starts spinning it up when i give it moderate acceleration when wet, traction control cuts out the power going to the wheels.
    During the dry times, its annoying when merging with heavy traffic from a standstill, you give it some stick and the power cuts out. by the time u get going again, theres a car doing 70km/h up ur tail
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    With mine, while ur driving, go to turn the T/C off, park the car, go to do something, come back. The T/C will be on when u turn the car back on.
    I agree there is a smoother ride with it off, tats cause the car doesnt lurch when give it some stick.
    The Blue One
    Quoted for truth
    VY S pack & VP ute
    Jun 2008
    does anyone know of a way to have it off by default? instead of always having to press the button after you start?
    gravel roads are a pain with it, out the driveway every morning and it kicks in
    VY S L67
    Nov 2007
    incorrect, it just reduces throttle.
    it cant change sides that it gives power to. it isnt an air locker.
    Its POS, its more dangerous if you start pumping a bit of power through the rear, and it singles/doubles and doesnt work, can make your rear end go strange
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by taztassio View Post
    Yeah, if u reduce throttle then u reduce the power, same thing!!
    Ive lost u there! Ur car must do wired things then, cause mine doesnt do that.
    The Blue One
    Quoted for truth
  15. #15
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I think you will find that Traction Control works as an adjunct to ABS. It doesn't control the throttle, it controls the brakes to the rear wheels. As soon as the ABS sensor detects one axle starting to spin and lose traction, TC applies a braking force to that wheel to bring the wheelspin back under control. The force applied is extremely quick and much less than you would apply yourself, but it happens so quickly that the spin is controlled without the wheel locking up. Also,it isn't a constant pressure, it flucutates on and off, extremely quickly, again, faster than you could do yourself with the brake pedal.
  16. #16
    VY S L67
    Nov 2007
    nah it doesnt control brakes.
    its loss of throttle.
    cut your rear lines and you discover!
    also, thats coz i am pumping 160rwkw thru a single and a shift kitted auto that gives the diff hell, so it doesnt cope well
  17. #17
    2010 Voodoo Sv6
    Sep 2008
    ^^^^ Second that, it works on throttle.
    When i run my lpg trac control is always off and can't be used as the lpg is injected using a different system
    Quote Originally Posted by Cousin Slow Poke View Post
    Stick a gerbil in your pants!
  18. #18
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    OK, to clear things up:
    Traction control intervention operates in three stages; engine spark retard, throttle angle reduction, and rear brake application.
    The first is less noticeable; with only a power sag from the engine being felt as the ABS/ETC control module requests the PCM to retard the engine spark as appropriate.
    If the ABS/ETC control module continues to detect the rear wheels are rotating faster than the front, it will request the throttle relaxer control module to reduce the throttle angle.
    The final step taken to control the rear wheel is for the ABS/ETC control module to apply the rear brakes, thus reducing the torque to the rear wheels.
    ABS and Electronic Traction Control are the same system just doing different jobs. One protects from brake lock up, the other one stops the wheels spinning. Each wheel has a speed sensor to give the system all this info.
    This information is for VTs onwards straight from Holden.
  19. #19
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    It doesn't work the throttle.
    It uses the ABS and retards the ignition timing...
  20. #20
    Nov 2008
    Tullamarine, Vic
    soop, i guarnatee you it does. Get a Holden technician to explain it to you. But that paragraph in my above statement tells you the EXACT steps that are programmed into the vehicle. That is from the Holden manual, unless your trying to tell me Holden doesn't know what they did to their own vehicles? That's what was in the VT's onwards.... i can only gurantee its valid for up to the VYs (inclusive). Not sure if the VZ's are the same, i'd have to check that.
  21. #21
    vy ss commodore 5.7ltr
    Jul 2006
    traction control uses the abs to pulsate the brakes to slow stop the wheels spinning as far as i know,
    also can someone clarify this for me, do all vy ss's have traction control and if so do they all have a traction control switch?
    as my vy ss is a srz 1 auto and doesn't have a traction control switch and will still spin it up, but will do as stated in a post above that you will feel the back end twitch out around a corner say and the ass end will gently bring itself back straight, also its an ex unmarked cop car so not sure if that makes a difference or not.
  22. #22
    Nov 2008
    Tullamarine, Vic
    cpbait, all SS's have the Traction control..... EXCEPT in the base of the BT1's
    Quote Originally Posted by Holden
    Traction Control is deleted from "SS" models with P.O. A8V
    However, the BT1's DO have an LSD, which will help!
  23. #23
    Nov 2008
    Smithton, Tasmania.
  24. #24
    VX acclaim wagon S1
    Feb 2008
    sydney
    yeah some later commo's vy-vz, have traction control but no switch to turn it off, the switch sits behind your window switches.
    If you want it off cut the wire :P Pin B11 i think, its black/white trace
  25. #25
    Nov 2008
    Smithton, Tasmania.
    Is it possible to reverse the switch?
    So that TC is always off., and you switch it on with the button?
    Cutting wires is very ghetto...
  1. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  2. Traction Control on VZ SS
    By BLACK VZ SS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-04-2007, 10:53 PM
  3. Traction COntrol ON/OFF
    By Egnitevt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-01-2007, 10:01 AM
  4. VT traction control
    By GM 62 in forum Electrical Wiring / Questions
    Last Post: 06-01-2006, 09:39 PM
  5. Traction Control
    By skb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2004, 11:48 PM
