Warped brake rotors?
When driving at slow speed (I try and avoid this, but it has to happen some time) with a window down, I can hear a sort of 'scuffing' noise coming from the rear wheels. It sounds like it only happens once briefly on each revolution of the wheels, and because of this the sound is less obvious as road speed increases. I'm guessing here, but was wondering if one or both of the rear rotors is warped? I have removed both rear wheels in turn, and noted that the brake pads are in contact with the rotor. When the car was last serviced, I queried this with Holden and was told this is how the pads should be set up.
Has anyone else experienced this situation, and if so, is it a fairly common fault- and how can I fix it?
BTW, the car is a 2003 VY series 2 SV8.
Thanks!
