ECONOMY AND POWER AND CRUISE MODE
The programming in the Powertrain Control Module (PWM) provides for these three different shift patterns which are driver controllable, through the use of the Economy/Power button, located in the centre console.
Economy Mode
The calibration for this mode is for maximum comfort, with minimal intrusion of engine noise and smooth shifts under all driving conditions. When additional power is required for acceleration, full throttle upshifts are similar to those calibrated for the Power Mode.
Power Mode
When activated, the PCM modifies the transmission calibration in the following ways:
1. When the throttle is less than 80% open, later upshift points are provided.
2. Shift time is reduced.
The Torque Converter Clutch (TCC) will be applied in both third and fourth speed ranges.
Cruise Mode
When the cruise control (if fitted) is engaged, the PCM modifies the transmission calibration so that earlier downshifts and later upshift points are provided.
