+ Reply to Thread
Results 1 to 13 of 13
Thread: traction control button
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese... CANYONERO Calais
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    Default traction control button
    Is it possible to make the traction button work the wrong way round? as in its deactivated during normal driving and you can engage it when you want but goes back to deactivated on next start up?
    its just that i prefer to drive without traction activated and if i need it i'll use it.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Yes it's possible.
    Two ways..... Get a Tech 2 to do the work.... or create an electronic circuit to simulate Trac Control being pressed at startup (turning it off).
    TVR-190's Avatar
    TVR-190 is offline Temporarily Unbanned TVR-190 Senator TVR-190 Senator TVR-190 Senator
    WK Statesman V8
    Jun 2008
    Cronulla, Sydney - Australia
    couldnt you pull out the existing switch and re-wire it.
    my bad for bump.
    TVR-190: That LSD service paid off. Stato just got very sideways.
    Grennan: In a stato, the term is held starboard.
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais JBDrifter Executive
    VZ Calais & VT Exec Wagon
    Oct 2006
    Quote Originally Posted by TVR-161 View Post
    my bad for bump.
    I'm only taking a guess here but I would have thought that this switch is just a normally open push button switch... meaning each push of the button closes the circuit, sending a signal to the computer which then changes the state of the traction control electronically.
    Tech2 would have to be used to reprogram the computer to have the traction control set to off by default... or like alien said, a small circuit set up to simulate a press of the button on start up, maybe with the use of a small PLC or something?
    NVN07's Avatar
    NVN07 is offline Latress on the menjay. NVN07 Executive
    VY Spack Sedan
    May 2009
    Dalby, Queensland
    Sweer idea. I would love to do that to mine too. though i've made it second nature to turn it off so i would have to get used to not having to push it, lol.
    Let us know how it works out if you can get it done.
    "It's not who i am underneath, but what i do that defines me."
    My Hothouse VY S
    Mercedes C200K AMG-Sports
    Mar 2007
    I think because I have LPG install the TC is disabled... I'm not sure cause I havent tried to do a burn out yet but its getting wet here in WA so I'll give it a go next time at home.
    VT spac super6
    Nov 2008
    Riverton sa
    trac is c**p and dangerous fullstop
    i cant see any situation i would want it.. unless you lend it to someone else i spose :P
    vy ss commodore 5.7ltr
    Jul 2006
    motec ecu's with traction control feature can be used for traction to be on or off at certain times i believe, but depends if you want to spped that much and go that far.
    VE Berlina International II
    Nov 2003
    It can be done... because they do it with the gas, just the only thing is when the car is switched to gas it turnds off
    Thats all right, thats ok, I drive a commodore anyway!!!!
    2004 VYII SS
    May 2009
    yep.... traction control can be dangerous at time's and just full on annoying to say the least... i thought about getting a techy to do something about it but then just decided to hit the switch when i clicked my seatbelt in as it's right there. way cheaper too.
    Lumps of cheese's Avatar
    Lumps of cheese is offline catch us if you can Lumps of cheese ClubSport Lumps of cheese ClubSport
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Why's it annoying?
    I've never had a problem with it. Unless you love smoking them up at every turn then it shouldn't matter.
    Nov 2008
    Tullamarine, Vic
    juzo, there are certain circumstances when it's better to be without it than with it! Due to it cutting all power you have to get out of a situation! There is a badly designed U turn near my place, every vehicle i've been in has the rear end slide out unless you take it at like 5km/h (which being a 70km/h road is not wise). Even when i was driving a front wheel drive pulsar the rear swung out, and they've got no weight in the back! Anyways, the other night, a fair bit of rain had hit and was lightly coming down, had to use the U turn, had TC on (forgot to take it off), next thing i know it had kicked in, car still kept sliding (270 degrees) and narrowly missed a light pole! If i had power i would've been able to control the vehicle better!
    2004 VYII SS
    May 2009
    yeah too right!! if it's not a situation like that it can be every day stuff even in the dry where for example you are taking a gap in the traffic to turn into a street and as soon as you start turning it causes a leap frog effect and just slows you down turning a simple safe manouver into a possible near miss, which will also make ya look like bit of a drongo too hehehe.
+ Reply to Thread
  1. VZ Sv6 " No Traction Control Button"
    By Rhodzy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-10-2009, 07:17 AM
  2. traction control button comes on when driving.
    By sa josh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2009, 07:31 PM
  3. LEDs in traction control button and rear power window switch
    By Jom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2008, 05:05 PM
  4. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  5. Traction control button
    By jarrod587 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2007, 08:40 AM
