+ Reply to Thread
Results 1 to 9 of 9
Thread: How to fix steering volume control
    VY series II Berlina
    Feb 2009
    Default How to fix steering volume control
    Hi
    VY Series II Berlina.
    Problem. Steering volume controls only increase volume, even the mute button.
    I have searched the forums and the only answer to this problem I have found has been "Fixed under warranty"
    Sadly I am the second owner and the car is not under warranty, I bought it at the gov't auctions
    So
    Has anyone had any experience with this problem that can give me some hints so I can fix it myself?
    DC
    Junny's Avatar
    Junny is offline purrrrrr Junny Executive
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    think its abit technical. because from what i heard each button sends out a different voltage? and then the cd player reads it and does whatever the specific current does. dont know if thats clear but yeah. take it to a holdren dealer. dont think it would cost much
    VY II Adventra LX8
    Feb 2009
    Mine did the same and the fix was to replace the controls - not a cheap fix over here - about $200 - charegd an hours labour to deactivate air bag, remove steering wheel, replace the controls and now it works.Still has a slight fault in that sometimes when the radio is off and you turn a corner and hit a bump at the same time the radio will come on. No a real problem as it has only happened twice since the steering wheel controls were replaced and the radio/CD is on most of the time anyway.
    ashbox's Avatar
    ashbox is offline 6 speed ashbox Executive
    something silver soon
    Apr 2007
    The Car
    yeah the buttons will set you back about $100, i had a problem with one of my buttons broke off. so for about $160 holdens should be able to fix the issue for ya.
    well i paid $97 for the buttons and then holden wanted 50 to fit them.
    Chev badges are an instant fail
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Or if you know what your doing with electronics you can assess the circuit yourself, if it needs new resistors, they're about 4 cents each from Dick Smith (there's only two). If you need new switches thats a bit more complicated and you will need new buttons.
    VY2 Berlina
    Jun 2008
    Castle Hill
    All you need to do is resolder all the dry joints. simple as that. So solder each join on the board, and it should be fixed. Its just a voltage divider circuit, so if anything goes amis, everything stuffs up
    vy s ute
    Mar 2009
    I have the same issue in a VY-S ute all buttons work correctly with the exception of the volume up which actually mutes the stereo! The paint has wron pretty quick on the wheel so may just swap it out for an hsv item off a wrecker.
    Nov 2008
    Tullamarine, Vic
    itol, you can either do that or remove the battery terminal from the car for a short while [about 5 minutes]. Sometimes the factory head units get confused. I know at one meet i went to the vol up turned the volume up, and the vol down button also sent the volume up! Could only turn it down by the head unit!
    daniel555's Avatar
    daniel555 is offline Custom VY Commodore daniel555 Executive
    VY Executive S2
    Apr 2009
    Vic, Australia
    Mine does the same thing now, Most of the time it works normally, But times i press mute, It'll change the mode, I press volume up and it'll change the mode again, Lol. its weird, But im getting a sound system in it soon, So they'll almost be useless, Dont really use them anyway. :P
+ Reply to Thread
  1. Steering Wheel Radio Volume Button
    By SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-08-2008, 04:37 PM
  2. VY Steering wheel Volume buttons fuxxored
    By bradrogers in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2007, 12:36 AM
  3. Steering Wheel Volume up button
    By jordanaki in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-10-2007, 12:06 AM
  4. steering wheel volume control issues
    By letemlaf in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-09-2007, 09:20 AM
  5. WTB - vx steering wheel control button
    By daz08 in forum Swap / Wanted to Buy / Trade
    Last Post: 23-07-2006, 10:01 PM
Tags for this Thread
