When u pulled down the fuse cover, is there are label that tells you the location of the fuses (on the inside of the cover)?
Most likely & relay, check the long black box on the left hand side, in front of the strut tower.
hey was jsut curious if there is a fuze somewhere for the fog lamps on a y series r8? checked under dash but dont appear to be any. neither fog lamps turn on when switch is on.
The Blue One
have you checked the loom is plugged in the rear of the spotties :P ?
