+ Reply to Thread
Results 1 to 9 of 9
Thread: painting wheel hub and calipers
    VY S2 S Pack
    Jan 2009
    Whyalla S.A
    Default painting wheel hub and calipers
    im thinking bout painting my wheel hubs black and the calipers red. just wanting to no is it hard to take the calipers off and if not when u take the calipers off are they likely to close up.
    any help would be appreciated
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW one_and_only2004 Calais
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    from memory the calipers are held on by two bolts on the rear. Provided you don't have the brakes on or apply brakes they shouldn't clamp up.
    Make sure you whack on some locktite when you're putting the bolts back in.
    VY SX "The Silver Fox" - 237RWKW Blown V6
    VZ Thunder - 360RWKW Turbocharged V8 - Tuned by BPS
    VY S2 S Pack
    Jan 2009
    Whyalla S.A
    so when i take them off make sure i dont pump the brakes before removing them
    Commydoor's Avatar
    Commydoor is offline born in the FB era Commydoor Berlina
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon andyman Senator andyman Senator andyman Senator
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    when i painted mine, i took 1 caliper off and got the shits with it cause it took so long, so i just taped the hose off blanketed the painted surfaces near by and sprayed them,
    i took the mounting bracket off and painted those off the car
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash DUK13Y Executive
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    vy ss commodore 5.7ltr
    Jul 2006
    i painted my calipers red, i just taped up everything and didn't remove or undo the calipers and was ok, didit in a hurry but did 3-4 coats and worked out better than mates that had removed calipers.
    Mar 2008
    i threw a sheet over and in the guards of the ute , then went crazy with a spray can, waited an hour, went and locked the brakes up to clean the discs, then changed the pads. No bolts needed to be undone bar the pad ones.
    VYMAD's Avatar
    VYMAD is online now SILVERFOX VYMAD Calais
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I just papered and taped everything up and painted them on the car with some left over engine enamel, I read the paint instructions, leaving so long between coats etc. Took about 4 hours to do all four, including taking to the calipers with a wire brush then wiping them over with metho prior to paint. Months later still looks awesum, shiny and no worries.
+ Reply to Thread
  1. Painting Calipers..
    By WannaHsV in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-02-2009, 04:59 PM
  2. Painting calipers
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2008, 02:35 AM
  3. Painting calipers
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2006, 06:11 PM
  4. Painting Calipers
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 09:08 PM
  5. Painting Calipers
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2005, 07:39 AM
