just use a vy one ?
inlet plenum is slightly different then earlier ones, and last vy motor we bought was only 650 dollars for round 70000klm on it
Hey guys, looking for a spare engine for my ecotec vy comodore to rebuild. what other models house the same engine as a vy and would be a direct swap...
not sure if vn, vp's used different sensors in things like that.
cheers,
eclipz
just use a vy one ?
oh ok sweet. not that dear then... looking to turbo one.. do you know what modifications would be needed for a stock motor? internals?
depending how much psi you want to run, but the list is almost endless for the ecotec, crank, rods, piston, cams etc, to rebuild with performance parts = $1000's,
you may be better off plumbing your turbo up to your existing engine, work out a tune, all plumbing, than transfer to the new motor once built, or old one flogged
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
try buying a 2nd hand supercharged motor and use it? Think internals are slightly stronger then non S/C motors
l67 =D
boost it allll you like
