+ Reply to Thread
Results 1 to 3 of 3
Thread: Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    VZ SV6
    Mar 2005
    Default Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    Can anybody shed some light on this:
    I have noticed in all of my past and present Commodores equipped with V6's (VR, VT, VX, VY) that when taking my foot off the accelerator when cruising at 80 (for example), the tacho indicates the engine speed seems to drop and then momentarily increase and the drop and then increase again, and this continues to occur until I slow to around 60. The speed ranges by only a small amount, maybe 300-400rpm's at the most, and unless you're watching the tacho you wouldn't notice, except in the case of my VR which had a 2.5" exhaust and you could actually hear the engine "revving" itself.
    I'm sure that this happens for a good reason, the ECU must purposefully cause this fluctuation to overcome some other fuel/air or exhaust/vacuum pressure issue that must be inherent with the pre-Alloytec V6 setup.
    It appears to only happen in auto's, as my brother's VS manual V6 doesn't appear to do it.
    Does anyone know what's going on here?
    VY2 SS
    May 2004
    I had the same problem with my VS and it seemed to me to be the lock up torque converter causing this.
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    well i had the same when i had a 2.5" lukey with 1 resinator at the rear!!! however problem dissapeared once i fit extra muffler...i thought it might have beens something to do with back pressure???
+ Reply to Thread
  1. ECOTEC idle problem
    By syk35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2011, 11:24 AM
  2. ecotec idle speed adjustment
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2007, 07:17 PM
  3. Ecotec Stumble off idle.
    By squidda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 10:34 AM
  4. how does the ecotec engine idle?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 03:35 AM
  5. VT V6 Ecotec Idle Revs Range
    By iamset69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2005, 10:58 AM
