+ Reply to Thread
Results 1 to 5 of 5
Thread: wiring gauges in vy
    VY Commodore
    Sep 2008
    Camden, NSW
    Question wiring gauges in vy
    Hey guys,
    I bought the aftermarket gauges (oil pressure, water temp) and gauge holder that goes on the dash and was just wondering best place to tap the red 12v power wires into that run off the gauges. Have not done alot of wiring myself so if someone could point me in the right direction that would be great.
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    The 12v power line you could connect it to any fuse in your fusebox that switches on when the car's being powered by accesories and more. Or many people just splice the wire going to the cigareete lighter to use that. However with the VY's they're a little different and can be switched on without the key in. But still easy to do.
    VY Commodore
    Sep 2008
    Camden, NSW
    Nov 2008
    Tullamarine, Vic
    No problem.
    When doing it via the fusebox though, i suggest you tap into it BEFORE the fuse, and then place your own fuse on it for the guages too. For the simple fact that if you do it AFTER the original fuse you could overload that fuse and find that it keeps blowing.
    Easy way to test, is to goto the fuse you want, check it works the way you want it to with an automotive test light. Remove the fuse, and only one side of it will cause the light to come on, use THAT one! And add your own fuse in the line.
    VY Berlina Series 2 5.7l
    Oct 2009
    Quote Originally Posted by zacrach83 View Post
    Hey guys,
    How much are these to buy?
+ Reply to Thread
  1. wiring diagram for vy binnacle gauges??
    By Lumps of cheese in forum Electrical Wiring / Questions
    Last Post: 16-02-2010, 05:47 AM
  2. wtb: gauges
    By jonno_12 in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2007, 12:04 AM
  3. Gauges, wiring/installation?
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2006, 10:40 PM
  4. WTB : Gauges
    By Goon in forum Swap / Wanted to Buy / Trade
    Last Post: 22-03-2006, 10:25 PM
