Results 1 to 7 of 7
Thread: Missing After Plugs/Leads
    VY 03
    Aug 2005
    Default Missing After Plugs/Leads
    Ok this one has got me Changed plugs then took the car for a drive it was fine until about and hour later i started to get a miss. So i got a new set of decent leads but that didn't help, checked the plugs today and they all looked ok. So i'm confused I was thinking could it be fuel filter? If it was a dud plug would it come up on the computer if i had it checked at a mechanic?
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Check again that all leads are properly connected. If that fails go through one by one changing the spark plugs back to the old ones to make sure one of the new ones hasn't died.
    VY 03
    Aug 2005
    I had just come across a post i had not seen before about the Gap being 1.5mm I will have to check that out and if one is out then i guess that would be the problem? but i am sure i set them correctly But i will have to double check.
    VY 03
    Aug 2005
    I did a reset on the computer today and still same problem. If the plugs are not all set at 1.5mm gap would that be the problem ?? And yes the leads are fine. And could not see any shorting in the dark.
    Senator Slash's Avatar
    Senator Slash is offline Slashman
    VYII HSV Signature Senator
    May 2008
    Hamilton, NZ
    Had the exact same problem on our VS v6. Ended up getting new HTleads and the problem didnt go away so all that was left was the plugs. (I didnt check the gap when i fitted them doh!) most likely your problem.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Very common to get a dud plug. Use one of your old plugs and taking it in turn, swap it with the new plugs until you find the dud one. If it doesn't fix the miss you will have eliminated the plug question.
    Visit my Facebook page
    VY 03
    Aug 2005
    Im going to check all the gaps this week then do the plugs So hopefully i will get some results Thanks for the help (me thinks gaps could be out a tad)
  1. ute missing when idle plugs and leads change
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2007, 06:26 PM
  2. PLUGS and LEADS
    By statesman_wagon89 in forum V6 Development And Modification
    Last Post: 30-03-2006, 03:03 PM
  3. Plugs/Leads
    By Spyper in forum General
    Last Post: 27-12-2005, 11:19 PM
  4. Plugs and leads
    By SS57 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2005, 11:06 AM
  5. plugs and leads
    By savage1987 in forum V6 Development And Modification
    Last Post: 06-06-2005, 05:54 PM
