Results 1 to 7 of 7
Thread: Central locking question
    VT exec
    Sep 2008
    Default Central locking question
    Hi there. today when i came to unlock my car wit the remote the driverside lock only lifted up half way and door was still locked.
    in order to unlock door fully i had to use the key which opened the lock up all the way. this only happened to the drivers door.
    whats wrong and how can i fx it? thanks in advance
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Most likely the door actuator (device used to push up the lock) is sticking, best thing to do is to take off the door trim & try to get the actuator out.
    Best thing to use would be good ol WD40, this will free up the mechanism.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    damsgirl is offline Mumma to 2 boys
    VS
    Jan 2009
    Noble park
    VY Exec Wagon
    Oct 2007
    Frankston
    Quote Originally Posted by PaulSV6 View Post
    or put some graphite down the hole
    VN S1
    Jan 2008
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    Quote Originally Posted by damsgirl View Post
    battery in key flat?
    once the signal is sent it either gets there or doesn't meaning it either unlocks or it doesn't.
    Pull the trim off, lube it up with something and have a play while the trim is still off. it is possible the actuator is weak with age and the slightest friction is causing it to not operate properly.
    2004 VZ S-Pack Ute
    Jan 2009
    Gladstone QLD
    Had the same problem in my VS as mentioned i pulled the door trim off found the mechanism and lubed it up good! lube is always ure friend
LinkBacks (?)
  1. 14-03-2009, 07:48 PM
  1. central locking
    By brooksy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2011, 09:41 AM
  2. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  3. Central locking
    By newo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2009, 08:56 PM
  4. Yet another central locking question
    By KiwiHoldenDriver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2008, 01:50 PM
  5. central locking
    By stewart in forum Electrical Wiring / Questions
    Last Post: 30-10-2005, 02:23 PM
