Hi guys, just wanted to know what springs to get for my vy exec. It currently on 19's and is sitting very high. Also am wanting to install an ss kit so was unsure how low i can go any feedback would be great thanks.
Prob best to go a spring shock combo, cause if u just get springs the shocks will last about 6 months & you'll get a s**thouse ride.
My 2 cents would be kings springs low or super low & Monroe GT sport shocks.
Remember dont go too low or you'll have scrubbing issues.
The Blue One
2" all round on 19's should keep your car about 13cm from the ground with SS kit. depending on the kit of course...
Find yourself a custom shop and go tell them what you want. They should be able to sort you out.. all comes down to $$
Make sure you replace the shocks aswell as springs.. its expensive but you'll thank yourself in the long run.
Have a squiz here:
KYB / Kings Commodore Lowering Packages!
Depending on how low you want to go you may need a camber kit, especially if you're running 19's...
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
If you plan on using this car on the street, you may want to double check the height allowance with your insurance company first. I had a bit of a run in with NRMA as they only allow something like 1.5".
Thanks guys, was also wandering should i wait and put the kit on first before lowering or does it not make a difference?
Was given a quote from The Tyre Factory and they said $800 for King Springs plus Monroe Sports Shocks. Does this sound like a fair price?
Yes that is the price installed. I also called the place in Moorabin who gave me a quote of $990 so the $800 is looking pretty good. If i go with lows will i need a camber kit seeing as its on 19's? Or even with super lows will I?
