Results 1 to 20 of 20
Thread: Check Enigine warning light.
    Vy Exec
    Feb 2009
    Default Check Enigine warning light.
    Hi guys today I was driving on the freeway and all of a sudden a warning check engine mode camed on were my Kilometers appear and trip computer as this was the first time it has happened.I checked the Temp of the car and it was still on quarter and the car was running perfectThe warning then went away after 5 mintutes and didnt appear again.Got home quick and lifted the hood up to do some random checks.Oil was all good,Water all good ,checked leads etc and some wireing.Started the car and as usuall it did a system check and then said ok.Went for a drive and didnt do it again ???.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Did it give any error codes?
    If not, just take it to Holden, might be a software fault somewhere!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Senator Slash's Avatar
    Senator Slash is offline Slashman
    VYII HSV Signature Senator
    May 2008
    Hamilton, NZ
    Sometimes on start up mine does this if I actually wait for the system check sometimes it says check service or something and wont start. I turn the key off and on and it is fine to start again.
    I will let you know what Holden says when I take it in.
    VY Executive S2
    Dec 2005
    Ive had it many times only in summer above say 35c and only with the aircon on!
    It will play the tune and give the engine check symbol display and often will
    stay on until you turn the engine off.
    Now holden always give the line ahh its nothing to worry about its a software glitch.
    My guess is the auto trans in my case is getting hot.
    Triggering the sensor.
    Regards
    Fred
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Yes, you see the thing is, when the warning lights comes on it's fine.
    For example, if you put a hole in your sump [still a sore point atm].
    You can drive for about 150 metres before the "Check Oil" light comes on. Thats when you switch your car off straight away to avoid damage!
    Jump out and look at gaping hole in sump.
    Curse a little bit.
    When getting it onto a tow truck you need to put it in igntion stage, and self test starts, runs and says OK. Even with absolutly no oil because it's all over the road. After that its ready to go, but wont warn you again! As soon as you get an error like that you should pull over!
    And just for future, your coolant temperature comes up with a different screen to Check Engine. It actually warns about the Coolant Temperature in the error message.
    VY Executive S2
    Dec 2005
    Auto tans oil temp via the raditor was what I am guessing can cause
    the engine temp warning, been a while since i read the service manual but
    I recall a couple of auto related error codes can give the engine temp light.
    My engine temp guage stays between 1/4 and 1/2.
    Regards
    Fred
    VY Executive S2
    Dec 2005
    VY Executive S2
    Dec 2005
    Had the car in for a service and got holden to check the error codes.
    O2 sensor and they cleared the error.
    Now at least I know what it is ,looks like a intermittent sensor.
    Have brought 2 new bosch sensors and when I have time will fit them.
    Regards
    Fred
    Vy Exec
    Feb 2009
    Quote Originally Posted by f_vos View Post
    Regards
    Fred
    Mine still comes on now and then engine check tune and then goes off in about 5 mintues.I dont think it's got to to do with the trans heating up as it does it when the cars cold to.Maybe cause i put it on lpg I dont know.What a O2 sensors mate and were can I find them in the engine bay to check them out and what causes them to go ??.Cheers
    Nov 2008
    Tullamarine, Vic
    What causes them to go? AGE. Where are they. Look just after the headers on your exhaust and you'll see wires going into a little thing that sticks out of the exhaust pipe. Those are your O2 sensors. Basically they just tell the vehicle how rich or lean the fuel is that's going into the engine. It's basically the replacement for the Chokes.
    Vy Exec
    Feb 2009
    Quote Originally Posted by alien View Post
    Thanks mate for the info.I'm wondering do you mean the headers in the engine bay, or the exhaust underneath the car??.Going on what your saying on what the there function is it could be the O2 sensors as I put the car on LPG only a month ago and I took it for its first gas service 1500ks and they played with the fuel mixture and adjusted it previous to that the warning did not come on.
    Nov 2008
    Tullamarine, Vic
    From memory you should be able to access them from the bonnet. But they are a fair way down (and only do it while exhaust is cold). If not, you have to access them from under the vehicle. I only say from memory because it's been almost 2 weeks since i looked at a VY
    VY Executive S2
    Dec 2005
    Smile
    Put 2 new Bosch sensors in and it drives like a new car + NO sign of the engine check warning.
    Regards
    Fred
    Vy Exec
    Feb 2009
    [QUOTE=f_vos;1099049]Put 2 new Bosch sensors in and it drives like a new car + NO sign of the engine check warning.
    Is it hard to change them mate?? and were are they located exactly?.Thanks mate
  15. #15
    Nov 2008
    Tullamarine, Vic
    Tiger28, really easy to change, unclip from wiring harness, then just use a spanner to undo them. Reverse for fitting them. The ones in the VY's are a little harder to get to than say something like an 89 falcon, but still it's an easy job to do.
  16. #16
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I've been told that you should sand the exhaust side where the o2 sensor contacts exhaust when changing them to ensure good earth.
  17. #17
    Nov 2008
    Tullamarine, Vic
    The O2 sensors arn't earthed through the exhaust pipe... only ones that would be if they were would be the Supercharged engines and the V8's as they have the heated O2 Sensors. With a N/A vehicle they have 2 wires, both of which goto the PCM, one for the voltage and one for ground. Both units are grounded, but return to different points on the ECU, so that it can monitor the O2 sensors properly.
  18. #18
    Vy Exec
    Feb 2009
    Hi all.Took the car to my local Mechanic and he plugged his computer under my steering colum to see why the check engine was coming on.Told me nothing camed up no error or bad codes.He then had a look at the LPG system used some impco computer to and did some adjustments and fine tuning and said see how it goe's now.Told him about O2 sensors, and he said may be it because they play up sometimes ,but it doesnt see to be it as nothing camed up on his computer reading.I'll see how it goe's.
  19. #19
    VYII Wagon Dual Fuel HBD
    Jun 2005
    O2 sensors do degrade over time, after all the working environment is harsh to say the least. It is also possible to inadvertently fool the sensor into giving a lean signal, which will not affect the running of the car but will trigger the fault warning and code. (Code 13 on some models, not sure about others) I have done this a few times with both my Commodore wagons when towing the race car. On a trailing throttle as you descend Mt Victoria or Mt Ousley, both long steep descents, the fault warning can illuminate but as soon as throttle is applied it will go out. Just for that period it was sensing a lean signal, but no overall harm done. Hope this helps....Regards Kev
  20. #20
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Had issues with my O2 sensors (4 wire) in my '99 S/C V6 and they said it was the earths on the block!
  1. Airbag warning light after headers install and brake check??
    By Curtisb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2009, 12:07 AM
  2. Check engine Warning
    By Joshua in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-09-2008, 11:42 AM
  3. check oil warning
    By vycalais in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-03-2008, 05:27 PM
  4. What Oil Is Best For My Enigine?
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2007, 05:32 PM
  5. Check engine warning
    By liberator81 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2005, 12:36 AM
