Results 1 to 8 of 8
Thread: Fixing broken fuel flap
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Default Fixing broken fuel flap
    Hi Guys,
    I broke my fuel flap the other day (snapped it off the arm that holds it to the car). It broke off at the join of the flap and arm. I spoke to a plastic welder and they said they didn't have the plastic to fix it since it's a special plastic (anti-flammable or something), so i might try gluing it up, and if that fails then get a new one and get it sprayed. Was wondering has this happened to anyone and what glue did you use?
    Thanks,
    Adam
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Y not just buy a new fuel flap, rather than trying to fix the broken one.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    you'll probably have more luck making a metal arm which screws/bolts it back together. Glue will break eventually (also losing it on the road = not cool ).
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    surely you cant just buy the plastic arm from holden. A mate of mine did it reccently and his still confused as to what to do about it
    VY SS
    Feb 2008
    The arm and flap are one mould, you cannot just replace one bit as its one assembly. I would buy a new one holden (about $35), but they don't come colour coded which mean i would need to get it sprayed (about $40). Money isn't an issue, but getting it sprayed would mean the colour is off with the rest of the panel (although it is already since the flap is plastic and panel is metal), but would rather use the original one to keep the colour match as close as possible.
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    Yeap I did the same thing to my VT wagon..
    First off I used super glue just to hold it in place, then I used a heap of sikiflex to cover the whole lot, it looked a bit messy but it worked.
    Try it if it doesn't work then worry about buying a new one & painting it..
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    fixed the one in my VX wagon, 8 months ago and still going fill up once a week, just regular old superglue the 2 mix type.
    ucrvme's Avatar
    ucrvme is offline [UCRVME]
    2003 Holden VY Berlina
    Mar 2009
    Melbourne, Victoria
    Holden calls it a reinforced flame retardent coating.. and i highly advise against drilling new holes, what about heavy duty epoxy glue.
  1. Fuel tank door broken...
    By WhiteVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-05-2011, 02:07 AM
  2. Centre console flap broken...
    By anonymousmoose in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2009, 04:17 PM
  3. WTB VR Fuel filler flap - sherwood green
    By dontsailbackwards in forum Swap / Wanted to Buy / Trade
    Last Post: 23-07-2006, 12:49 AM
  4. VN fuel flap
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-08-2005, 08:08 PM
  5. Fuel Gauge Broken
    By PretendFriend in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2004, 01:11 AM
