Results 1 to 11 of 11
Thread: Horn Issue
    rippen50's Avatar
    rippen50 is offline Wants a Manual =]
    VY Executive 3.8L
    Apr 2007
    Camden
    Default Horn Issue
    Yo all... my horn has been playing up for the last 6 months that being it not working when i press it i checked the fuse it was blown.. so i went and got 4 new fuses and every time i put one in and pressed the horn it would blow the fuse!!
    what do i do? cheers
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    rippen50's Avatar
    VY Executive 3.8L
    Apr 2007
    Camden
    the horn's not the problem it a switch or the electrics or something i just wanna no if anyone knows what to do
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    unplug the horn & see if the fuse still blows, you should find it doesnt, then get a new horn
    rippen50's Avatar
    VY Executive 3.8L
    Apr 2007
    Camden
    in saying that how to i disconnect the horn? do u mean from the actual horn or from the steering wheel
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    No, it's connected with two wires, behind the bumper on the driver's side. You have to get down on the deck to see it, below the headlight. Just pull one wire from the horn and try the horn button. If the fuse doesn;t blow, the horn is the culprit. If the fuse still blows, check the relay. Swap it over with a similar relay from the fuse box. I think the horn relay is located in the engine bay in front of the driver's side suspension tower. It's under a clip-on cover which will show you which relay to check. (Fuse and relay lay-out moulded on underside of cover)
    You can see from the labelling on top of the relay which ones are the same to try the swap.
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    last post = solution.
    get air horns !!!!!! I have got them and they are ****en grouse
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    rippen50's Avatar
    VY Executive 3.8L
    Apr 2007
    Camden
    VYII 5.7L V8 Calais
    Mar 2005
    Sydney, Australia
    ucrvme's Avatar
    ucrvme is offline [UCRVME]
    2003 Holden VY Berlina
    Mar 2009
    Melbourne, Victoria
    Quote Originally Posted by sp001in View Post
    Hey Dude, I wanted to get air horns in my VY Berlina i called this auto elec an he said its not possible because my bay is full up - im curious what car do you have and how many horns do you have?
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    There's enough room in a berlina to fit air horns. I was going to install some but put in my lancer instead, not that it has a huge deal of extra room anyway. I managed to find enough room to mount 5 trumpets and the compressor in both cars so yes there is room. Might have to make some brackets to mount them though. Install yourself, don't need an auto electrician.
    A Commodore is a passion. Anything else is just a car
  1. intermittent horn issue
    By Timmos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-01-2009, 12:34 PM
  2. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  3. Replies: 3
    Last Post: 03-02-2007, 09:51 PM
  4. Horn In a VL
    By Trewman in forum Electrical Wiring / Questions
    Last Post: 19-01-2005, 12:08 AM
  5. Horn Pin
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2004, 06:38 PM
