Results 1 to 7 of 7
Thread: where is the vacuum tube on the vz alloytec motor?
    vz sv6
    Mar 2009
    Default where is the vacuum tube on the vz alloytec motor?
    i want tstall a vacuum gauge does anyoneknow how too and where is the tube ? that you need to tap in on the alloytec motor ?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    at the back of the manifold, buy a 1/4 inch t piece, i think its 1/4 or smaller, cut the tube before the one way valve on the a/c controls hose (the small one), dont use the brake booster hose
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    vz sv6
    Mar 2009
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by AlfieBoY View Post
    is it the white thing ?
    the one way valve is the white cylinder looking thing with the hoses on either end of it,
    insert the t piece between the valve and the manifold
    05 VZ Berlina
    Mar 2010
    Hi all!
    Just got a VZ Berlina V6 (had a VT Berlina) and have looked at the white valve on my Alloytec. It is connected just before the heater tap. Is this correct? Seems strange and should it be on the other small black hose that goes to the manifold? I think that's how my VT was.
    Thanks.
    I am getting a vacuum tester and want to know where it should really hook in.
    Delish-VY is offline Banned
    2003 VY S pack
    Jan 2010
    Originally - Eastern Suburbs - Melbourne, Currently - Cairns
    correct me if im wrong guys but I think you might get more help if you asked this question in the VZ section where the VZ owners will be able to help you out?
    05 VZ Berlina
    Mar 2010
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
LinkBacks (?)
  1. Motor knocking - Alloytec 6
    By MrCalais in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-05-2008, 01:52 PM
  2. VL aircon vacuum tube matchup. HELP!!!
    By dibly1980 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2006, 09:40 PM
  3. Vacuum hoses on Varijet + 202 Blue Motor, VH Commodore
    By Dr_Mutley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2006, 02:00 PM
  4. Tapping from alloytec 190 motor
    By Walks_SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-05-2006, 03:03 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
Tags for this Thread
