just bought some fog lights for my vy and just wondering is it straight forward to install these lights or wat?
at the hole on the bumper at the back of it there is a cable hanging down?
Maybe, Series 2 VY's usually don't have the driving light wiring. (series 2 usually does)
Might have to wire it up yourself. You need an SS light switch too Unlees you put another switch somewhere. Plus a relay and fuse (or combined relay/fuse). I did write up a tutorial about a year ago, but its seems to have disappeared.
-Jase
Every (k) over is a THRILLER!!
Yea, i've noticed in mine theres a wiring harness there too. From memory its the same as the driving lights loom, probably because the lights were an optional extra. I'm not sure how they operate though through the BCM, i'd need to look into that. But i would put in aftermarket lights and just run my own wires.
The Blue One
PaulSV6, in the S packs thuogh there is no switch to switch them on seperatly. So i'm not sure how the BCM handles the driving lights and when it switches them on! I'd need to look into it with a wiring diagram that i dont have in front of me atm.
Ok, so one thing he still needs to buy is the switch.
Are we talking about Fog lights or driving lights, cause they would be wired differently again. Driving lights turn on when u flash ur high beams & fog lights should only come on if u have ur parkers or low beams on.
The Blue One
If the wiring is all there, then you need a relay for in the engine bay, and a switch to replace the existing one.
The one thing that i can't remember is if you need to run another wire from the switch to the cluster to illuminate the tell tale. (Think this is only if you have to wire up).
i put fog lights in my SV8, the wires were taped up under ther front, cut the original plugs off, hooked my lights to them, added a relay in the blank foglight spot and a SS headlamp switch and it all works. i need to figure out if i can put a globe in the cluster to let me know when there on though.
so the cable hanging down is for fog lights all i need to get is and ss interior switch
and a relay
no longer a hoon by association - the commodore is gone
The ss interior switch is bout $50-$80 from holden maby go 2nd hand
you will also need the main dash trim with a cut out for the switch
wat do u mean main dash trim with a cut out? im ordering an ss interior light switch from holden dont they push in and out to activate the fog lamps
They pull out to activate to activate the foglights![]()
The Blue One
