Results 1 to 3 of 3
Thread: changing from petrol to gas - stalling!
    VYII acclaim
    Mar 2009
    Question changing from petrol to gas - stalling!
    Hi,
    I just bought a VY II commodore acclaim which is on duel fuel. Ive found it a bit rough starting up. Im new to duel fuel so maybe its how it is? After its been running a bit its fine. But also Ive tried to change from petrol to gas when idolling just after i start up, and it stalls. This is also then same if im driving and try to change from petrol to gas. Is this normal?? It seems to be fine when changing from gas to petrol.
    Help!
    Thanks in advance.
    SwordFish is offline Banned
    vZ
    Mar 2009
    When you change between fuels, put the car in Park, raise the revs to about 1500rpm and THEN press the button, should work fine.
    Source: I have a VY on LPG!
    vy with SS kit
    Mar 2009
    Quote Originally Posted by Jay09 View Post
    Hi,
    Help!
    Thanks in advance.
    +1 Swordfish
    it will always stall(regular lpg setup) if you try and switch from petrol to gas, unless you hold the revs high 1500-2000. My gas man recommended to avoid changing from petrol to gas while engine is running as it could possibly backfire.
  1. Stalling when changing fuels (LPG conversion)
    By The Moose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2008, 01:42 AM
  2. Stalling (auto V6) when changing from reverse to drive. Help!
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 07:32 PM
  3. Stalling when changing gears(N or R to D) - cleaned IAC?
    By Raging Bull in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2007, 01:44 PM
  4. Stalling when changing gears
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2005, 06:46 PM
  5. vr stalling
    By StatOmaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 01:55 PM
