Results 1 to 12 of 12
Thread: Air horn install
    rippen50's Avatar
    rippen50 is offline Wants a Manual =]
    VY Executive 3.8L
    Apr 2007
    Camden
    Default Air horn install
    How is it done?... i have all the parts just would like to no if its easy enough to do it on your own
    Thanks
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    I installed one onto my mitsubishi lancer a few months ago. The hardest part is finding room to mount them. I removed my alarm siren just to mount it . I also made a small bracket and drilled it into the firewall with a self tapping screw. Works fine.
    Not sure about how you'll mount it into the holden engine bay as there isn't a huge deal of room to add trumpets and it'll be a real pain in the ass if yours is a 5 trumpet horn like mine Good luck with it
    As for the actual install, once all the horns and compressor are mounted you just get some 8mm hose (may have come with package) and soften the ends with hot water so it's easier to slip over the hole. So that should set all the actual horns up but then to wire it up, you need a separate switch from your car horn as it's illegal to replace your standard car horn with a air horn, and mount that somewhere in the dash. I just used a small round push switch. Pull your wiring through the firewall (harder than you'd think. I used a long metal wire to get 50/50 through then tied the wire onto the end of that and pulled through) and hook up your switch. I soldiered mine on so if your gonna do that, do it before you fully mount your switch.
    Hook up your relay somewhere in the engine bay and put the other end of wire you ran through onto the relay. From there you can simply just run your negative wire onto a part of the chassis and you power through to the battery. Make sure your power wire doesn't touch the chassis when juiced up so try to keep it neat and tidy. You'll want to run a small fuse on your power wire too. You can get this and the switch from Jaycar for about $5-10 total depending on what switch you use.
    Test it out and should all work. Good luck with it. If a 16 year old can do it, I'm sure you can.
    A Commodore is a passion. Anything else is just a car
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    did this already. EASY bro! all the wires are already down there. just plug the the new wires into the air pump. will instantly work. Take the wires from the current horn
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    As far as I was aware, you were not allowed to replace your current horn with an air horn. The air horn had to be fitted to a separate switch from your original so that your regular horn still works. That's why you can't use original wires.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Quote Originally Posted by DUK13Y View Post
    Yep thats pritty much what i did with my vs, but i installed the trumpets under the head lights near the front bumper (theres planety of room there), just using a few L shaped brackets.
    sp001in's Avatar
    MALOO R6
    Jul 2005
    QLD
    YEP............................................... ................................................
    enough said.
    98 VT brake fluid affected Commodore Executive
    Aug 2009
    Has anyone used a truck air horn ie a MACK horn, or is everyone talking about those $50 ones from Auto One. I am currently trying to find out the volume of air that is needed to get about 5 medium length blasts from a resevoir tank holding between 110 - 150psi.
    I dont know if that made sense but I need help!
    email me at thespike05@hotmail.com
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    Speaking of putting airhorns in cars, is there any way to just grab one of those beastly sounding horns out of a VY Calais or Statesman and chuck it in a lower model (eg. executive, berlina etc)?
    Cheers people.
    rippen50's Avatar
    VY Executive 3.8L
    Apr 2007
    Camden
    VS Acclaim
    Dec 2010
    wondai
    VY SS
    Jun 2006
    Albany
    Quote Originally Posted by dah_man_ben View Post
    Cheers people.
    if they are similar to my ss then they will have multiple horns
    Cosmosis is offline Space Cadet
    VY S
    Oct 2011
    Hawkesbury
    I have a set of airhorns in my S pack. I have a Stebel Nautillus horn mounted in the factory location and a 150Db low tone trombone mounted behind the front bar. theres plenty of room for airhorns behind the front bar infront of the condensor. Airhorns must be run off a seperate relay as the pump draws approx 15A which will blow the fuse every time.
  1. Horn not there
    By Lipdog81 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-03-2009, 10:15 PM
  2. Horn keeps going off....
    By CANYONERO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-07-2008, 10:00 PM
  3. Horn??
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 11:42 PM
  4. Replies: 3
    Last Post: 03-02-2007, 09:51 PM
  5. VN Horn Pad
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2005, 07:18 PM
