Results 1 to 7 of 7
Thread: Engine Cuts Out
    INDACLUB's Avatar
    INDACLUB is offline Black VX SS
    Black VX SS, White VQ 5ltr
    Apr 2008
    Default Engine Cuts Out
    Hi guys, the last few weeks when stoped at a corner and going slow out of a corner my engine cuts out and the steering and brakes go hard. The battery light comes on and the car wont start straight away. The cd player, air con and power windows still work. Its only since i had a Mafless tune. It only happens once a week. It pretty dangerous when cars are right up your arse and going across a intersection. The cars a VY SS.
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    first thing, check you battery terminals, my car was playin up something shocking, found my terminals were loose and it was fine. if that fails, bring it back to the tuner as its not right.....
    INDACLUB's Avatar
    Apr 2008
    Went back to the tuner today and he connected the laptop up and he couldnt find anything wrong. He said everything seems to be running fine. No errors came up, but he said it sounds like it is electrical.
    On the way home from work it done it twice and i almost had a very bad accident with a truck.
    Anyone else know what it could be.
    Senator Slash's Avatar
    Senator Slash is offline Slashman
    VYII HSV Signature Senator
    May 2008
    Hamilton, NZ
    Just because the tuner says it isnt related to something he did, if your car was fine before that Id still be on his case.
    It could be anything causing it. There is more than likely some error codes. If the engine just stalls and wont restart straight away you can bet it has generated a log.
    It could be a little glitch in his idling maps or anything.
    I recon go to your local GM dealer and ask them to Tech II the codes for you then go to the tuner armed with this information.
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    The guy who tuned it wouldn't be lying about no codes.
    I had the same problem and no codes showing up, crank angle sensor was changed and hasnt happened in probley 9 months.
    Sensor would overheat and cause the car to stall.
    INDACLUB's Avatar
    Apr 2008
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    probably is something to do with the tune, but first thing first man take the car off the road before you get injured.
  1. engine just cuts out
    By Pimpin' VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2006, 12:51 AM
  2. engine cuts out
    By al2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2006, 09:21 PM
  3. VR Engine Cuts Out
    By tommo824 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 03:56 PM
  4. vn engine cuts out
    By willi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2005, 04:11 PM
  5. Vn Engine Cuts Out
    By arty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2003, 01:04 AM
