Results 1 to 8 of 8
Thread: vy supercharged questions
    VY CALIAS L67
    Apr 2009
    Default vy supercharged questions
    hey everyone. iv been on this website so many times trying to find specific questions. but unless there hidden i couldn't come across them.
    any ways i have a VY L67. 88000km no mods.
    1.what i want to know is. if i put a 10PSI pulley on its own without any other mods. what power will i be looking at.
    2. that hsv xu6 190kw memcal. rubbish or worth the $160
    3. high ratio roller rockers. are they better than the 10PSI pulley
    if i do all 3 mods what power will i be looking at in kw
    if any1 whos done these mods could help then it would be greatly appreciated. thanks
    vy ss commodore 5.7ltr
    Jul 2006
    i have never had a supercharged v6, but http://v6supercharged.com.au/ should be able to help you out, they have a lot of experience with supercharged v6's.
    BIG-EV's Avatar
    BIG-EV is offline Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    Hey the best thing you can do with ya L67 is a boost upgrade it can run 12psi non intercooled easy and probs 14psi with smaller iridium spark plugs. for the xu6 chip ur only changing ya performance by 9 flywheel kws (hardly noticable) so its better holding off till you done ya other mods then custom dyno it. the pulleys and small belt ur looking at round $550. FIT will custom make any pulley size from 8psi to 22psi.
    get ya pulley first as the rockers wont do much with low PSI. if you want a new cam shaft is a better option with crow cams doing a good custom grind one that has over .5 lift. but u still have to install them. Mace engineering or fit do a 1.98:1 ratio rockers which will require new push rods otherwise 1.95:1 will fit fine.
    if you looking further down the track you can inter cool it but yeah have a look around.
    Im about to finish my supercharged ecotec engine build with it running 25PSI boost through a blizzard intercooler kit and onto ACP racing heads. got a custom grind cam and looking to produce around 450HP-500HP at the treads and all is available from a low 2000 rpm
    VY SII HBD Calais L67
    Dec 2006
    The pulley upgrade is the first step and do rockers later if you want more. The rockers wouldn't actually give you more power withough having 1st done the pulley upgrade because you wouldn't have enough boost to utilise the extra lift from the rockers.
    87mm pulley is the go. Don't buy into this 10, 11.5, 12, 14 psi crap as the 87mm (10psi) pulley is the best starting point. any more than that and the ecu will be retarding timing hard and that send the power backwards. It's a good idea to do a bit of a cold air intake improvement and some cooler heat range plugs after the pulley while running on 98octane fuel all the time too. The ECU will optimise its settings to get the best of those mods.
    Power wise if you will get about 140 - 150rwkw with a pulley and rockers. A full exhaust helps but at least a cat back is a good start but doesn't really make more power until you are well into modifying the L67.
    The post above mine refers to 450-500rwhp.....forget that. It's a myth and will not happen. The fastest VT L67 in AUS has around 330rwhp on a good day and it runs high 11s and has one of everything on it with extensive dyno and development time just as an example.
    edit: forget the XU6 chip IMO, the stock ECU is very adaptive and with the CAI, pulley and rockers it is more than capable of accomodating them well so you can save your dosh
    VYII Calais L67
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by joeythehungarian View Post
    For answers to what you seek look here:
    www.l67torque.com • Index page
    By the way great looking car.
    SW
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VS l67 statesman
    Dec 2008
    Listen to surfwagon , and go on the website everything you need to know is on there & shop around for the parts you want, there are some big price differences and quality issues
    Im glad someone put me onto the site before I started to spend
    Mar 2008
    VY Calais Supercharged
    Sep 2008
    Auckland, New Zealand
    Just thought I'd put my 2 cent worth in. I've got a supercharged VY calais and its got the following mods, 3.2" pulley, SS inductions cai, Yella Terra 1.95 rockers XU6 chip and I have a set of 1 3/4 pacemaker headers and a VZ Clubsport exhaust waiting to go on when i find the time (damn house renovations haha)
    The pulley and cai are what i've found to be the best seat of the pants mods so far, and have a look on ebay in the states for a pulley because you can pick them up for $90 US brand new and they are very well made.
    The chip didnt make any huge power increases and nor did i expect it to, but the engine does rev out cleaner, drive smoother and it reduced the knock retard and the trans program really livened up the shifts and made them more positive.
    As for the rockers I think the car only went better because my wallet was way lighter after buying them, but that may change with the headers and exhaust.
    Having said that Yella Terra rockers are beautiful and they are the only rockers i have ever used or considered using on my 308 race engines and I would probably have brought them regardless.
    Now off to see if I can work out how to get the bloody center console out...................
  1. too much $ for a vt supercharged ?
    By coasty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2008, 09:17 AM
  2. 5L or supercharged 6 in a WB Ute
    By 5LWBUTE in forum General Discussion
    Last Post: 20-12-2008, 12:49 AM
  3. Supercharged 6 Questions
    By gregstar in forum General
    Last Post: 25-06-2008, 08:26 PM
  4. a few questions about the supercharged motor
    By sv9946 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 02:38 PM
  5. Vp Supercharged how much
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2005, 09:37 PM
