Results 1 to 16 of 16
Thread: srs
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    Default srs
    now it might be my imagination but my srs light is staying on longer than it used to anyone know what that means?
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Does it go off? How long does it stay on for? It's normal for it to stay on longer than the Holden Test that happens at startup.
    If it doesn't go off you've got a problem, if it does, then dont worry.
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by SAV_117 View Post
    lol i thought mine was doing the same. o.O
    Hit the star under this post if it was any help to you =D
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Quote Originally Posted by alien View Post
    it goes off just stays on longer than it used to lol
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Nov 2008
    Tullamarine, Vic
    LOL, then dont worry about it, it's all good if it actually goes off! Dont worry about it just yet?
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Nov 2008
    Tullamarine, Vic
    If it gets beyond half a minute, then start to get suspicious about what it is!
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    i had a similar thing with my vx lumina the srs light stayed on for less than 30 seconds but when i crashed it the airbags never went off and i hit a Mazda CX 7 at 70km
    Nov 2008
    Tullamarine, Vic
    vx_rosso, the srs system is complex. It WILL however report if an air bag is faulty or seat belt pretensioner. The system will NOT always inflate the air bag(s), it simply depends on the conditions. But most probably your seat belt tensioners were activated, if not, then the srs system deemed it unsafe.
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    oh ok then cheers ive always wondered why they didnt go off it stuffed the car good i think it was somethin like $20000 worth of damage
    Junny's Avatar
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by vx_rosso View Post
    so your car blew up? coz 20k is ave for vys now if you get what i mean
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    this was in a vx lumina here are some pics of what i did to it
    Attached Thumbnails Attached Thumbnails srs-13092008-001-.jpg   srs-13092008.jpg   srs-23092008.jpg
  15. #15
    Nov 2008
    Tullamarine, Vic
    For deployment to occur, numerous factors must be taken into account. For instance, the crush area of the other vehicle (if involved in the crash), its mass and speed would all contribute to raising or lowering the force required for deployment to occur as designed. As a general rule, for front air bags and pre-tensioners, the angle of impact force will be within the 60 degree window for SRS deployment to occur (refer Fig. 12M-2), although the physical damage to the vehicle may appear that it was.
    The sensors that control the front air bags and seat belt pre-tensioner deployment are incorporated in the Sensing and Diagnostic Module (SDM), located beneath the centre console.
    There are two sensors (peripheral acceleration sensors) that control the deployment of the side air bags; one in the left hand B pillar, and the other in the right hand B pillar. If a peripheral acceleration sensor detects a crash situation, it will send a signal to the SDM requesting a side air bag be deployed. If the SDM is in agreement, deployment will occur.
    Regular maintenance of SRS is not required. If at anytime the SRS warning lamp comes on while driving, or does not come on when the vehicle is started, there is a system fault and this must be rectified as soon as possible.
    Thats straight from the Holden Manual.
    Judging by your damage the SDM decided not to set them off! And it doesn't look that bad anyways so i can see why not. If it was written off you should've grabbed the air bags, they're expenisve to replace, and people pay a fair bit!
  16. #16
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    cheers for that alien yea i should have now as i look back on it but at the time i wasnt thinking bout that was in to much pain from copping the steering wheel to the chest and whiplash
