ive snapped the pipe that runs between the manifold and the cat. no places are open today as its easter and tomorrow is a public holiday...i have $1100 to spend if i have to, if anyone knows were i can get it fixed or where i can pick up some parts privatly this afternoon or tomorrow.
its an LS1, im thinking i may aswell upgrade it a bit while im at it so if anyone has any info or advice its apreciated
cheers
how did it snap?
could it be welded or did it snap from excessive rust?
maybe ring all your mates and see if they know anyone with a welder that could help you out.
a slab goes a long way.
yer, hit a bump and it just poped. it lookes a bit rusted out....i might see how the mates can go with a welder...does it take much effort getting that part of the exhaust out ??? i know it all looks pretty tight in there..
shouldnt be too hard.
pretty sure its a flanged joint at each end.
exhaust manifold - flange - pipe - flange - cat
should just be 4 bolts to get the section of pipe out.
ok cheers mate...ill give it a shot i suppose i cant do any more damage..
i think i have a v8 pipe here. in the garage.
goes between the header and the cat. its bolt in and out.
same thing you are after?
i pulled it off today, the pipe flares and has a bracked that fastens it to the manifold. the cat it joined to the same peice of pipe and has a flange that connects to the rest of the system just after the cat. is this what you have ??? im really keen to find one tonight so i can drive to work tomorrow...
