Results 1 to 12 of 12
Thread: HSV Grille??
    VY SS 6 Speed Manual
    Mar 2009
    Northern Adelaide
    Default HSV Grille??
    Hi peeps,
    Am looking at removing my Chev grille (which i'm sure plenty of people here will be happy about) & replacing with something different. I wanted to try and find something with the HSV badge on the front (around the same size as the Holden badge that comes stock). Also instead of the black plastic that is on either side of the badge i was just looking to mesh behind, or alternatively have 2 chrome bars on either side of the badge.
    Does anyone know if something like this exists or am i going to have to get one made up? Any advice on anything similar would be great!
    i think i have made my-self clear....Let me know if your unsure what i mean, post was kind of hard to explain. lol
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    Mar 2009
    Northern Adelaide
    Cheers Sav, yeah i remember seeing that some where on here before. Pretty similar to what i am looking for, would rather chrome instead of the black though. I guess it should be relatively easy to lay hands on a HSV badge the same size..... Did you make that up yourself?? Take long?
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    i cut out the middle sections and cut the mesh to size than i got my plastic welder to fix up all the imperfections and such and paint it and weld the mesh to the grille lol
    Mar 2009
    Northern Adelaide
    Oh ok, sounds easy enough....If you have a plastic welder....I didnt know they even existed. i thought there were only metal ones.! lol
    lastlegend's Avatar
    lastlegend is offline Phantom VY SS
    2003 Black VY SS + 1999 Silver VT Olympic Sedan
    Sep 2008
    Thorneside QLD
    Quote Originally Posted by Mavr1k View Post
    Hi peeps,
    You could try what I did and that is to remove the centre completely and replace with mesh, I see no problem with then placing a HSV badge in the middle to make it stand out.
    anyone modded there vy exec grille???
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Not sure there is such a thing as a HSV grill as the grill/front bar etc on HSV are all one piece.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Quote Originally Posted by lastlegend View Post
    Hey mate,
    Just wondering how you went about removing the grill?
    I haven't had a look yet to be quite honest, but how is it held in?
    Cheers.
    Edit: Nevermind, decided to get up off my arse and have a look, heh. It's quite simple, really. : \
    Mar 2009
    Northern Adelaide
    Quote Originally Posted by minux View Post
    Yeah, that's what i was thinking. I like the HSV front ends, but dont really want to replace the whoel thing. Might have to go somewhere and get it made up. There a few custom places around. I havent been able to find a HSV badge the size i was after either.
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    Quote Originally Posted by jameswh View Post
    Hey mate,
    Cheers.
    Its really easy, there are three screws on the top side of the grill, remove these then gently push the bottom of the grill back so you release the two clips without breaking them then lift it out.
    Removing the centre will require a little more work and a dremel tool to cut it out. once the centre is out its just a matter of filling in the missing sections with off cuts from the removed section, filling and sanding smooth.
    I recommend you use a spray putty to fill any small sections that need it and finish off with satin black bummper spray paint.
    Good luck,
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    I think you will find they don't make a badge that big from HSV you may have to see if you can get a custom one made or use a standard bonnet badge with a bigger chrome or brushed alloy backing disc the size you need.
    Mar 2009
    Northern Adelaide
    Thanks for all your tips people. Will hunt down somewhere that will knock me up a custom badge, then will see how we go from there. Thanks again
  1. Replies: 25
    Last Post: 21-02-2008, 05:42 PM
  2. aftermarket grille?? or good grille?
    By vt_on_20s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2007, 09:38 PM
  3. Which grille is this?
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-01-2007, 03:40 PM
  4. vy grille
    By blackgully in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-08-2005, 09:21 AM
  5. Grille
    By jafo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2004, 05:36 PM
