Results 1 to 4 of 4
Thread: rough running ls1 when cold
    vy ss wagon
    Apr 2008
    Default rough running ls1 when cold
    Hi there my ls1 runs rough when cold but its fine when the engine is warm. Could the coolant temp sender be on its way out?
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Running rough has nothing to do with coolant temp sender
    When was the last time ur car had a service? Could be ur injectors are clogged up, bad batch of fuel etc........
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Baldric is offline The BOSS
    VE GTS M6
    Dec 2003
    replace yoru fuel filter next to the tank. and clean your filter, but ls1's are common to run a little rough when they could but once they heat up they seem to go ok
    ___________________________________
    Car: 07 VE SSV 6LTR L98 A6
    Metalic Silver
    vy ss wagon
    Apr 2008
    Had the injectors cleaned only 10k ago and replaced the fuel filter at the same time, hopefully its only a bad batch of fuel. However when it runs rough when cold it also has a big flat spot down low once you get past that it drives ok.
  1. V8 running rough / missing when cold
    By VeePee8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2012, 03:23 PM
  2. vt rough running
    By Jaybee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:37 PM
  3. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  4. VN SS running rough cold???
    By vnss_1 in forum V8 Development and Modification
    Last Post: 25-11-2008, 07:38 PM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
